Results 1 to 27 of 27
Thread: Re: La Cimbali Junior D Restoration - Help Appreciated :)
    Latte Lament
    Jul 2010
    90
    Hi Guys
    I have just acquired a La Cimbali Junior D!
    It appears to be an ancient model with bakelite handles?
    If anyone can give me some advice that would be great as i have never restored anything like this before.
    Dont know if I am crazy or not to attempt this but should be fun... I hope* :o
    Edited to reduce image file size for our bandwidth challenged users. Please keep pictures to about 100kb file size
    Dec 2006
    Perth WA
    572
    Hi,
    Does it work at all?
    Or is it a complete rebuild?
    Latte Lament
    Jul 2010
    90
    I havent even tried to start it up yet as i dont have the right fitting for the tap hose. So not sure what condition its in. But i am suspecting its broken.
    Here are some more pics of the inside
    Latte Lament
    Jul 2010
    90
    Lots of surface rust and gunk.
    Below is the left side view
    Latte Lament
    Jul 2010
    90
    The right side - a bit blurry
    Latte Lament
    Jul 2010
    90
    Bits under the boiler
    Latte Lament
    Jul 2010
    90
    See the floor pan!
    Its rusted out bad, so will need to source a new one somehow :(
    Rang a few parts places but they dont have them, they suggested i get a sheet metal place to fabricate one but i bet its $$$...
    The front right leg popped right through the rust when i put it on the table so yeah...
    Latte Lament
    Jul 2010
    90
    Also noticed this dodgy looking sheath, hope its not woven asbestos* :o
    Can anyone help identify it?
    Also Im in Perth does anyone know a cheap fabricator or happen to have a "spare" cimbali Jr floor pan just lying around... ;D
    Latte Lament
    Jul 2010
    90
    I think i know why there is so much rust in the floor pan!
    Latte Lament
    Jul 2010
    90
    Its Aliiiive!
    Well sort of, it turns on and I hear a healthy hum, but turned it off quick as I have not been able to attach flowing water but a good start.
    ... And yes the particles under the machine are flaked off bits of rust* ::)
    Jun 2011
    683
    A word of caution - you need to establish whether theres water in the boiler before you go switching things on willy nilly. Id suggest pulling one of the terminals off the element (with the machine UNPLUGGED of course) until you can make sure the autofill is doing its thing.
    Latte Lament
    Jul 2010
    90
    Thanks Rick
    Yeah the boiler has some water in it as i heard it sloshing around when i moved it into my car :)
    But I was worried about doing damage so only had it turned on for literally about 5 seconds.
    Wont be turning it on again until I have the water connection for it.
    Hopefully nothing was harmed from when I tested it quickly :-/
    Latte Lament
    Jul 2010
    90
    Ok Some progress.
    I still dont have the right plumbing fittings but got impatient, so I cable tied my garden hose onto the water feed line from the machine.
    Latte Lament
    Jul 2010
    90
    So I then fired the old gal up, and was surprised to see the water reservoir fill up...
    Latte Lament
    Jul 2010
    90
    The little ball in the glass viewer went to the top out of site, and the boiler started to boil...
    Latte Lament
    Jul 2010
    90
    The pressure guage went to about 1.5bar I think...
    Loud clicking from the Sirai Pressurestat - Damn that thing is loud!... :o
    Latte Lament
    Jul 2010
    90
    Some slight water sputter and steam from a valve on the top of the machine...
    Latte Lament
    Jul 2010
    90
    Then the orange light winked off...
    Tried the steam wand and the pulled a shot of water through the group and...
    She Works!!! ;D
    Latte Lament
    Jul 2010
    90
    But the old gal still has some probs:
    1. Sadly the water tap doesnt work!
    2. The valve below the water tap is leaking a tad
    3. Badly Rusted Floor pan needs replacing
    4. She needs of a good wash. ;D
    So does anyone have an unwanted floor pan lying around and any ideas what might be wrong with the water tap? ;)
    Im thinking scale in the line or possibly the knob is not opening the valve inside?
    Oh and any ideas on the weird steam tip?
    Thanks guys
    Feb 2012
    Perth
    46
    I think I remember seeing this old girl on gumtree not long ago what a bargin and great project machine.
    Dec 2004
    Earth!
    15,793
    Quote Originally Posted by 796572677C787066150 link=1337917329/14#14 date=1338344862
    If the ball goes up out of sight the boiler is being overfilled. If it only goes as high as in your picture then its fine. :)
    Quote Originally Posted by 796572677C787066150 link=1337917329/16#16 date=1338345050
    Thats the anti-vac valve and some steam and sputtering from it on start up is normal. Once the boiler starts pressurizing the steam and sputtering should stop. As part of your restoration I would do a rebuild (Descaling and replacement of washer and o-ring.) of the valve.
    Java "Still loving his Cimbali" phile
    Latte Lament
    Jul 2010
    90
    Hi Javaphile
    Yeah it kept rising and disappeared out of sight...
    I am assuming it would be the autofill probe level?
    I will figure out how to adjust it and see if that helps, but could it be anything else if its not that?
    Thanks mate
  23. #23
    Dec 2004
    Earth!
    15,793
    Quote Originally Posted by 524E594C57535B4D3E0 link=1337917329/21#21 date=1338362330
    Most likely. :)
    Java "Probe what?!?!?" phile
  24. #24
    Latte Lament
    Jul 2010
    90
    Okay I took the water tap arm off last night due to it not working.
    Blew into the tube and no air flow so that ruled out the boiler fitting.
    I love how this thing is designed, I just had to take the c-clip off the turning assembly and it all pulled out.
    Out dropped a bit of scale, gave it a clean and put it back together.
    Blew into the tube and now there is no more blockage :)
    So next thing is to fix my overfilling boiler, hopefully its just that water level probe.
    Once its all working right then i will attempt the strip down when i get a new floor pan.
  25. #25
    Latte Lament
    Jul 2010
    90
    Opened up the brain box and all the electronics are in good nick :)
  26. #26
    Senior Member artman's Avatar
    Jun 2006
    2,429
    Good work.
    Re the steam tip, there are a few varieties of tips for this machine (at least 3), so you have a bit of choice. Mine has 4 holes all pointing out at an angle. I have reduced the size of the holes and it works great.
    For the overfilling boiler, take out the probe and clean it with find wet and dry, if its not clean it could be preventing the boiler fill working.
    Re the base/pan, can you cut out the bottom rusty bit, leaving the surround, then weld/rivet a new base plate?
    Apr 2013
    3
    Same project...
    Hey, I'm just about to start exactly the same project on a late 1980s Junior D - looks the same as yours.
    How did your restoration go? Any tips for me?
    Quote Originally Posted by Latte Lament View Post
    Hi Guys
  1. Cimbali Junior S - How old
    By shsdarwin in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 14th March 2011, 03:47 PM
  2. Cimbali Cadet /Cimbali Max /Cimbali Junior manual
    By cremaluver in forum Grinders
    Last Post: 15th February 2011, 03:26 PM
  3. Replies: 0
    Last Post: 1st December 2007, 06:50 PM
