Results 1 to 8 of 8
Thread: Would you replate the inside of the boiler?
    Jan 2012
    Hobart
    43
    I am rebuilding my LaCimbali M30, I notice that the inside of the boiler and the hx tubes are back to bare copper, would you leave it or get it replated?
    I am guessing that it is inox or nickel.
    thanks
    Lee
    Aug 2004
    2,312
    Re: Would you replate the inside of the boiler?
    As far as I am aware nothing is plated inside, only sometimes on the outside and that is not compulsory by any means.
    Jan 2012
    Hobart
    43
    The LaCimbali appears to be platted on the inside, the hx tube are also silver inside and out except where they are back to copper.
    Jul 2007
    2,288
    Copper has some toxicity, although it usually only occurs if acidic food is cooked in copper pots and pans. Normal water would absorb only a minimal amount.
    Nickel is much more toxic, and a potent allergen.
    Apr 2012
    497
    My inclination would be to not replate, plate eventually wears off (as you can see from your boiler) and depending on what the plate is that means potential nastiness in your water.
    As GregWormald says, Nickel is more likely than copper to do "bad things" (tm) (its more reactive than copper) so Id be inclined to leave it as raw copper, plenty of machines (in fact, Id think the vast majority) out there with unplated copper/brass boiler interiors.
    Jan 2012
    Hobart
    43
    Thanks for the replies, I have found a few posts that are making me wonder whether it is a stainless boiler with copper staining or a copper boiler with plating coming off...
    Lee
    Aug 2004
    2,312
    unlikely on both counts>
    Mar 2012
    1,275
    Quote Originally Posted by 6F6E606F6271666D030 link=1339479101/0#0 date=1339479101
    I have never seen or heard of "inox" ( S Steel ?) plating.
  1. should I replate the boiler while doing a restoration
    By betterathome in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 28th December 2010, 08:14 AM
