Results 1 to 2 of 2
Thread: faema due pump not primeing
    Aug 2011
    East Coast Canada.
    30
    i recently changed out the pump in my due to a fluid 0 tech pump and its been working great ever sinice, i moved the machine out of my basement and up stairs, the new water line is hooked up but i cant get the machine to prime or fill. When the auto fill kicks in the pump just runs and the leval isint going up, ive tried a few differnt things to get any air out but nothing seams to work, also if i press the manual fill paddle nothing is happening.
    I even tried to get the machine to self draw from a bowl of water on the table but it would not self draw at all.
    is my new pump bad allready ?
    Aug 2011
    East Coast Canada.
    30
    fixed, the plumbing disconnect had some kind of flow restrictor in it so i had to change out the valve, all good now. Silly plumbers.
  1. EM6910 no main pump, low hot water and steam pump. Had red light. now just not worki
    By bocos in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 9th February 2013, 08:25 AM
  2. procon pump - metal filter in pump housing
    By rider in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 13th November 2009, 12:17 AM
  3. Faema Family - no pump pressure
    By PhatBoy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 27th July 2009, 08:00 PM
