Results 1 to 22 of 22
Thread: LM Linea Rebuild
    Feb 2010
    46
    LM Linea Rebuild
    Hi All
    I thought some of you might be interested in this , Iv just started on a full rebuild of a customers 3 group low cup linea.
    Ill post up some pics as I go but heres the start.
    Covers Off
    Pipework out
    Group boiler out and split
    Groups stripped , Holy scale batman
    Senior Member mwcalder05's Avatar
    Jan 2012
    Sunshine Coast
    437
    Holy scale indeed!!! Can't wait to see the progress
    Mar 2011
    609
    Awesome photos - I'm so keen to see more, keep them coming!
    I'll be watching this thread!
    Mar 2012
    1,275
    Not stainless bolts in the group assy's then ?
    Feb 2010
    46
    Nope, being replaced when rebuilt though.
    Member micksquires's Avatar
    Jan 2012
    54
    nzcoffeetech how old is that Linea? Can't wait to see it come back to life
    Feb 2010
    46
    Im not too sure , im guessing a reasonable age judging from the look of it, the frame is away being modified so ill check when it comes back , hoping to have the piping and boilers back from sonic cleaning early next week so will update when I start to rebuild.
    Oct 2011
    25
    I learn so much from watching you guys doing these restorations. Keep coming with these nice photos.
    Feb 2010
    46
    Update , got the boilers and pipework back from cleaning today so started putting it back together.
    Nice clean frame.
    Freshly cleaned and descaled boilers
    Boilers bolted in on modified mountiing points to give slightly more cup height.
    Getting there , new terminal blocks.
    Just waiting on group manifold gaskets then they can go on and be plumbed.
    Thermostats , valves , steam taps , switches ect. are all new. Only reusing solenoid valves as they are still good condition.
    Hot Water outlet has been relocated between groups 2 & 3 as the customer didn't like it so close to the R/H wand.
    Jun 2011
    683
    Lovely detailed work. Are you planning on fitting a PID or keeping the thermostat?
    Senior Member askthecoffeeguy's Avatar
    Oct 2006
    Preston, victoria, 3072
    817
    correct me if I'm wrong but PID for all boilers and line pressure to the groups for manual soft infusion?
    Feb 2010
    46
    Its all staying as it was , so just traditional thermostat. The customer had a limited budget so we had to keep it to a minimum.
    However to make it look basically new everything external , ie. switches , taps , manometer ect is new.
    Feb 2010
    46
    Quote Originally Posted by askthecoffeeguy View Post
    Not on a Linea , The Strada has this as it requires individual boilers for each group.
    Jun 2011
    683
    Fair enough. As long as the probe is squeaky clean and you can set it accurately, they work really well. I saw a great thing the other week, which was to replace the DPST rocker switch with two separate single pole rocker switches (in the same housing) to independently switch the pump and solenoid. Simple, but a very effective Linea mod. Or, any other semi-auto solenoid group machine for that matter.
    Feb 2010
    46
    Quote Originally Posted by rick_bond View Post
    Thermostat is brand new with lots of heat transfer paste and the housing is clean as a whistle.
    That mod would be great on a single group machine but multiple groups could get difficult to manage and make it a pointless exercise.
    Jun 2011
    683
    Quote Originally Posted by nzcoffeetech View Post
    How so? Pretty much functions the same as a multi-group MP. It also doesn't affect the touchpads, just gives the barista the option of variable pre-infusion time on the manual button, if they want it. If not, treat it as one switch.
    Feb 2010
    46
    If one group is a few seconds behind the other , as soon as you start the pump for the first group , pressure in the second group will raise to 9 bar ( or whatever the pump pressure may be ) so would have a shorter pre infusion time.
    Hence my point of having to manage the shots carefully or it becomes pointless.
    Dec 2004
    485
    Here's a picture of a remarkably simple and effective line pressure to pump switch on my 2AV. Not to mention a reflection of my flannelette shirt
    Aug 2010
    356
    If you're wanting the machine to appear 100% new on the outside and the stainless panels are showing signs of scuffing and scratching, you might want to look at getting a linisher to refinish the stainless panels.
    We've been using one for a while now, and while it can't restore the panel finish to the original high polish, it can produce a nice grained finish and eliminate scuffs and shallow scratches, and the grained finish often looks nicer than the original highly polished finish. We've done a few Linea and FB70 rebuilds recently, and the finished product can actually look nicer than a brand new Linea straight out of the box.
    I haven't got a pic handy, but the image of the S gives an idea - linishing produces the grained appearance on the vertical faces of the S, rather than the polished upper surface.
    Feb 2010
    46
    Almost back together , I would have liked to have done more but the customers budget was well blown as it was.
    New anti suction steam wands.
    And finally making coffee again.
    Jun 2011
    683
    Ah I didn't realise it was an EE! Love how you've plumbed in the steam anti-vac lines, very neat.
    You might want to check the connections on the brew thermal cutout, from memory the switched connection is across the long side. But it's obviously heating, so there you go.
    Feb 2010
    46
    Yeah they are wired correct , that pic is before I made up some new wires to go to the element.
    The new wand kits come with the hose, t pieces , cable ties and stick on mounts so very easy to make it neat.
  1. 4 yo LM Linea 2 group
    By cosmicfluff in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 6th May 2011, 12:53 PM
  2. Linea PID
    By justing in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 14th June 2010, 09:05 PM
  3. LM Linea
    By dannyh in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 6th December 2009, 01:19 PM
  4. Linea
    By PhatBoy in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 21st July 2009, 09:50 PM
