Results 1 to 2 of 2
Thread: Brew pressure problem on Portofino
    Aug 2012
    1
    Im restoring an old Brasilia Portofino from 2003. Ive managed to seal all the leaks and Ive descaled it.
    Now to the problem. The brew pressure is only 4 bar , even though I tried to adjust it on the pump it doesnt go higher. Ive descaled the pump , with no luck.
    Could be a problem with the manometer ? Because i get about 60ml from the portafilter on 10sec, which is a good flow rate or? Or could it be the pump that needs to be replaced?
    Aug 2012
    Germany
    1
    Hi,
    it seems to be the pump. Rotary pumps need often to be replaced when standing long time without work. 60ml on 10sec. is normal with mainwaterline pressure and small injektor (or nozzle). u can install a manual pre-infusion switch to close the solenoid valve of the group and infuse with reduced mainwater pressure~2Bar for better taste. After for example 5-10sec. you start normal pull and turn the switch of.
    M.
  1. Portofino pressure problems.
    By Mark_Smith in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 16th April 2011, 03:22 PM
  2. Brasilia portofino 2gr pressure question
    By Mischa in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 27th October 2010, 11:29 AM
  3. VBM Super brew pressure problem?
    By ml27 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 22nd March 2010, 11:07 AM
  4. Silvia Brew Pressure problem?
    By beanmeupScotty in forum Brewing Equipment (non-machine specific)
    Last Post: 20th June 2006, 08:20 AM
