Results 1 to 4 of 4
Thread: Brita C150 filter bypass setting
    Jul 2012
    67
    Hi,
    I've recently purchased the C150 kit and have plumbed in my giotto evo. The filter bypass was set to 30 and I haven't moved it.
    It is directly plumbed into the machine so the water will only be used for the machine (have the fridge plumbed for drinking water).
    Since it is purely used for espresso should I be setting the bypass to 0?
    14,665
    Hello ogi,
    30-50% bypass is recommended for Melbourne.
    We have tested our water and run 50% bypass at le shed.
    Dec 2010
    Toowoomba QLD
    417
    Hi ogip,
    The two basic numbers you are aiming for is a Total Hardness of 68 mg/L and Total Dissolved Soilds of 150 mg/L. (Read around and you'll get a bit of variation but based on my homework these numbers would get the tick from most. Less hardness might result in less scale but will start to affect the taste according to the experts.) So I think the best approach is to measure what you're getting and adjust the BP valve to suit. The bare minimum is to measure the TH (either with strips or a kit from pet fish shop) and get that about right. Hope this helps.
    Pete
    PS one of my local coffee shops has a TDS meter and was happy to measure my samples - thanks Tim!!
    Jul 2012
    67
    Thanks Gents.
    Is it ok to take a sample from the machine? (Water wand maybe)? Or can I use the little drain that is on the filter head?
    The next step would be the test? Where in Melbourne can I get both the tests done?
    Thanks again.
  1. Brita 3-way Kitchen tap
    By Whiteman in forum General Coffee Related...
    Last Post: 8th September 2013, 07:36 PM
  2. Breville BB200 BM - Bypass delayed start
    By Christop in forum Roasters
    Last Post: 14th January 2013, 06:18 PM
  3. Brita Purity C filter
    By walshman in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 29th March 2012, 01:40 PM
  4. C150 water filter kit - installation
    By fatboy_1999 in forum General Coffee Related...
    Last Post: 4th December 2011, 03:47 PM
  5. Faema Elite Bypass Valve ?
    By faemalove in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 16th March 2008, 12:49 AM
