Results 1 to 2 of 2
Thread: Jura Impressa X9 steam issue.
    Junior Member SouthsideAmericanBulldogs's Avatar
    Jan 2013
    12
    Hi guys/gals, my work has a Impressa X9 in the lunch area and due to lack of knowledge/Care for the upkeep of the machine has been abysmal. Today when I went to steam my milk the steam was not only coming out of the manual wand but the automatic steam holes. I would assume that a seel some were has broken and is now letting it through. Any one with knowledge of this machine it would be appreciated if you could help with the situation as it is barely possible to steam the milk manually anymore. Cheers.
    Site Sponsor gilkatho's Avatar
    Dec 2005
    9/43 Lang Parade, Milton QLD 4064
    72
    Service Update
    I'll put an update here as I've just rejoined as a sponsor. I know you've probably already resolved this issue.
    In the Jura Impressa X9 it has a bank of valves which control the steam/water flow around the system. Depending upon the beverage selection, it will send steam to the cappuccino frother, the hot milk outlet, the steam arm outlet or release the pressure if not needed.
    In the scenario that is above, as well as the manual steam arm valve, the cappuccino outlet valve is slightly open allowing steam to escape in that direction. The most likely cause is lime scale. I would initially run the descale process using the Jura descaling tablets. This process is designed to get the descale solution into the valves and to allow them to open/close as controlled.
    Hope you resolved your issue.
    Wayne
  1. jura Impressa z5
    By drcoffee in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 14th July 2009, 03:51 PM
  2. HELP NEEDED - Jura Impressa X90
    By Drewcifer in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 10th April 2009, 06:10 PM
  3. !!SOLD!! Jura Impressa E65
    By cuppacoffee in forum SOLD
    Last Post: 9th October 2008, 10:30 PM
  4. Jura Impressa S95 For Sale
    By Carl_B in forum SOLD
    Last Post: 26th July 2006, 07:56 PM
