Results 1 to 6 of 6
Thread: LM GS/3 Vacuum Breaker Modification
    Mar 2012
    26
    I just purchased a 2nd hand GS/3.
    I have noticed a little steam and water coming from the vacuum breaker when she starts up.
    This can be upgraded to the new type that vents into the drain tray. Does anyone know where to purchase this as a kit?
    Simon
    Feb 2005
    2,782
    Can you remove it, give it a good clean and polish, make sure the o-ring is not sticking and possibly replace the o-ring? Usually works for my Grimac every couple of years or so.
    Mar 2012
    26
    Thanks Robusto,
    Have given it a clean and it seals ok. I read on thread on homebarista.com that these can fail, causing water to spill down into the brain box. Apparently LM modified the design about 2.5 years ago and it can be purchased as a kit for slightly older GS/3's.
    Simon
    14,665
    Hi Simon,
    It will be an anti-vac with a nipple to which you can attach a length of silicon tube. This system is used in Izzo machines and we carry stock of the valve.
    The attached photo of a VBM Domobar Super 2B will give you the general idea.
    Mar 2012
    26
    Thanks Chris,
    That is what I am looking for. I found the main issue today, the non-return valve on the mixer for the hot water temp control (for tea water) is passing back into the steam boiler. Have opened up the brain box and fortunately no damage, but I have a bit of work to do to get little bugger out.
    Do you stock one similar to this with a 90 degree barb? Vacuum breaker with 90 deg barb.jpg
    Simon
    Aug 2010
    356
    That 90 degree valve looks identical to the valves fitted to some Marzocco steam taps as an 'anti milk suckback' device.
  1. Via Venezia tripping breaker
    By noidle22 in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 17th April 2013, 10:12 PM
  2. Recently bought BZ40, Vacuum breaker not working
    By pup26 in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 14th January 2011, 05:24 PM
  3. adding a vacuum breaker?
    By raphec in forum Brewing Equipment (non-machine specific)
    Last Post: 22nd October 2008, 06:33 PM
  4. What is the function of a vacuum breaker?
    By NewToEspresso in forum Brewing Equipment (non-machine specific)
    Last Post: 10th October 2008, 11:03 AM
