Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Bazooka
Thread: LaCimbali m21 junior -water running thru the machine...
    Oct 2013
    3
    Tip any one? My "new" coffemachine, a Lachimbali m21 junior does not stop water from running out of it...
    Possibly a gasket or any other closing mechanism...
    Can somebody help me identify the problem so I can fixit, or my wife will probably sell it while I`m a away... :-)
    Dec 2012
    Newcastle NSW
    179
    Do you mean the waste water discharge to drain? Or water from group head?
    Oct 2013
    3
    Hi. Thanks! It`s from the group head. When I start the machine, it "drains" all the water.
    Dec 2012
    Newcastle NSW
    179
    I think my la cimbali is the same model as yours it has 5 buttons, i usually press the STOP button to start extraction and it will keep going until I press the same button again. During the extraction process there is a distinct pump noise, can you hear such noise or the water comes out of the group head due to boiler pressure only?
    Oct 2013
    3
    Thanks. The pumpnoise runs continously, and the stop-butten does not respond... could it be the electronic -I just changed the vibrating pump....
    Dec 2012
    Newcastle NSW
    179
    Yeah I reckon it could be an electronic fault. Perhaps time for the professional to take a look at it, unless you are a tinker and actually looking forward to the challenge. I hope your cimbali gives you years of coffee pleasure, mine certainly does!
    Skimlingen likes this.
