Results 1 to 20 of 20
Thread: Faema E98 S1 No boiler pressure
    Apr 2012
    47
    Hi,
    My Faema E98 is no longer heating the water in the machine and it's not building up any pressure.
    The last time i used my machine, the steam wand must have been left open ever so slightly. As a result I noticed that the boiler level indicator showed that the boiler had no water in it. It must've drained the water in the boiler because the steam wand was left opened, which must have caused the boiler pressure to drop.
    I then refilled the boiler and the machine still won't heat the water or build up pressure. I thought that if there was not enough water in the boiler that it would automatically shut-off.
    Any ideas on what it could be and how to fix it?
    Thanks.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,949
    I suspect a new boiler element is called for Adam.
    Senior Member artman's Avatar
    Jun 2006
    2,429
    Yes, especially if the boiler ran dry. You could check for power at the element to confirm, assuming you are qualified to work with live power etc etc. Or check for continuity of the element with the machine (and element) unplugged.
    Apr 2012
    47
    thanks for your replies. It seems like it is the element.
    I actually had refilled the boiler after it happened - so I now have a full boiler that I need to drain as well as replacing the element.
    I couldnt see anywhere where I could drain the boiler, is it possible to manually drain the boiler on this machine?
    Jun 2006
    2,429
    My Faema has a drain port on the side of the boiler. It is a barb you can attach a hose to, them crack the nut open on the barn and water drains out.
    The other way is just unscrew the element and have a container to catch the water.
    TOK
    TOK is offline
    Apr 2013
    697
    Or, if you cant readily find a drain plug, you could be super cunning and undo one of the unions on top of the boiler to insert a hose with which to syphon out the contents. Its a lot less messy..... I am not familiar with the specific machine but if the anti vac valve is on top of the boiler, that would be the first port of call.
    Apr 2012
    47
    I don't think the S1 has a drain plug on the side of the boiler like the A1.
    I found this article on the LaCimbali Junior DT1 and I cant see a drain plug like they have in the photo.
    LaCimbali Junior DT1 - Materials and Workmanship • Home-Barista.com
    Ive taken some photos and I cant see anywhere that resembles a drain plug, - maybe I am missing something?
    TOK
    TOK is offline
    Apr 2013
    697
    Not really....lots of machines dont have drain plugs
    Jun 2006
    2,429
    The item labelled "d" in the second pic in your link is the drain. Looks like yours does not have it. As others have mentioned, drain it through one of the other fittings, the anti vac valve is probably the easiest. Either syphon or tilt the machine over.
    Apr 2012
    47
    I think I'll siphon it as tipping it upside down might get messy.
    To refill the boiler after I swap out the element, can I just use a funnel to pour the water directly into boiler through the hole where anti vac valve goes?
    Jun 2006
    2,429
    You could do that I guess, or just let the pump fill it.
    You could disconnect the boiler element terminals initially if you were really worried about the element being dry on initial power up.
    Not sure if your machine is the same as mine, but on mine if the boiler needs filling and there is not enough water in the tank, the element is turned off.
    TOK
    TOK is offline
    Apr 2013
    697
    Quote Originally Posted by Adam1982 View Post
    Good idea to err on the side of discretion and do that instead of allowing it to fill itself under power.....just in case....
    Apr 2012
    47
    I drained the boiler and removed the element. I siphoned as much as i could out before removing the element and catching any water that was left in there.
    New element will go in tomorrow.
    Senior Member saoye's Avatar
    Jul 2011
    Adelaide
    1,006
    Have you already purchased the element? From memory there was a safety cutoff somewhere which prevents the element burning out. Essentially all it was is a red button which you have to push pretty hard to get. Once you hear a "click" it should reset itself and heat up again. If you haven't purchased the element already it's worth a try.
    But the element looks ready to be replace anyway from the pics.
    Apr 2012
    47
    That red button sits on the end of the boiler. I pushed it, filled the boiler and turned the machine on and nothing happened.
    The machine is about 11 years old and seeing the scale build up on the element really drives home the importance of using only filtered water.
    Apr 2012
    47
    Here's a picture.
    I really love at how easy these machines are to work on
    Apr 2012
    47
    I picked up a new element yesterday from Coffeeparts and installed it.
    The machine is now back up and running as normal.
    Jun 2006
    2,429
    Woohoo, great work. Christmas coffee!!
    Apr 2012
    47
    One thing I forgot to mention is that the original LaCimbali element had two holes for where the thermostat should sit but the Coffeeparts one did not have these holes.
    So if anyone was to do this in the future and wanted to keep the thermostat they would need to drill the two holes themselves into the boiler element.
    Jun 2009
    Moonta SA.
    6,949
    Pleased to hear you got it sorted out Adam.
