Results 1 to 4 of 4
Thread: L Cimbali Junior reno (OOOoo to be in Victoria)
    Dec 2009
    14
    just noticed La Cimbali Junior on ebay , only at $300 bid ( im reconditioning same , just spent on parts, and in WA)
    my junior is now in bits, some scale on boiler and elsewhere, someone advise on best product to chemically remove scale please?
    Tag
    Tag is offline
    Feb 2014
    1
    "Glitz,All Purpose Descaler Powder" available at Bunnings warehouse stores for less than five dollars. This is basically citric acid and the same as any brand name coffee machine Descaler that will cost you over $25 for same product,Good Luck.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    6,949
    Same old question with same old answer (citric acid) its not the same stuff, you can get this Clean Machine activated descaler from Chris at Talk Coffee $10 not $25.
    Citric acid will not dissolve scale completely, you may well finish up with a bigger problem than you started with.
    Member Burnsy's Avatar
    Jan 2014
    Perth Hills
    43
    Caps, did you see the Junior parts on Gumtree in Kalamunda, was there yesterday?
