Results 1 to 3 of 3
Thread: Need advice on Faema Due D92/A2
    Apr 2014
    1
    Hi, Iím newbie in here, just bought used Faema D92/A2, the seller said, "Purchased it from shop as fully refurbished machine and have never used it" Yesterday, connected water and power on ( no leaking or dripping) turn the switch on to 1 position, heard the pump kick, water glass level between 2 line, the bottom gauge from 3 moves to 9 (green) about 20 minutes or over top gauge move to green position and stayed there, but the bottom gauge turned back to 3 (blue position or little bit under 3). Just want to ask someone here, is it normal operation or something wrong, thanks in advanced.
    James
    Dec 2004
    Earth!
    15,795
    One gauge measures line/pump pressure, the one that went from 3 to 9. At 3 your pump is off and it is measuring the pressure of the service line. When your boiler fills or you pull a shot the pump turns on and the gauge moves, as it should, to 9.
    The other gauge measures boiler pressure.
    Java "Have fun with the new toy!" phile
    Toys! I must have new toys!!!
    Jun 2006
    BRISBANE
    1,998
    Nice machine mate. With right grinder and beans it spells Coffee Nirvana. Enjoy!
