Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By nzcoffeetech
Thread: Wega programming and backflush?
    Dec 2009
    14
    Hi, I recently purchased a second hand Wega EVD/2 ( great condition) I have some questions i hope someone can help with
    Anyone have a link to operators manual?
    If not
    1 How to program dosage volumes?
    2 procedure to backflush
    3 What is small toggle switch for. located high up on rightside top corner of front face panel ( above black squarish switch)?
    4 what is black squarish switch for ,located upper right side front face panel?
    Thank you in advance.
    Apr 2008
    Victoria, Australia
    2,095
    No problem, toggle switch for turning program function on, the other switch is for the cup heating element.
    http://coffeesnobs.com.au/documentat...l-english.html
    Last edited by Javaphile; 10th May 2014 at 05:14 PM. Reason: Changed link to the files local location
    Dec 2009
    14
    hey , thanks for responding, link is great and answers most of my questions , although still no clue on backflushing procedure via blank porta-filter etc.?
    Dec 2004
    Earth!
    15,792
    Quote Originally Posted by caps1 View Post
    Section 10 'Cleaning' page 73 of the linked manual. Halfway down the page:
    Delivery groups (except for ALE version)
    The cleaning of the internal parts of the delivery groups is to be performed weekly in the following manner:
    • replace the normal filter of the filter-holder with a solid one;
    • pour a teaspoon of a suitable detergent powder on the solid filter, and attach the filter-holder to the group;
    • use the delivery switch to set the group in operation;
    • repeat the above operations until the water comes out clean;
    • turn off and remove the filter-holder from the group;
    • rinse a final time, so as to remove any residual detergent.
    WARNING
    Do not use a solid filter to clean the machines with a lever group (ALE)
    Additionally, pull and discard at least one shot per group after completing the above procedure.
    Java "Manual? We don't need no stinking manual!" phile
    Toys! I must have new toys!!!
    Apr 2008
    Victoria, Australia
    2,095
    see page 73
    Dec 2009
    14
    gotya, was thinking maybe automatic cycle on this machine
    truth is, was in standard bloke mode
    press buttons , bolt, screw, fiddle ....if unsuccessful.........read manual or assembly instructions :-)
    Dec 2009
    14
    Ok , tried recommended procedure , no luck.
    Im wondering if there is a sequence to the programming, directions a tad unclear.
    Anyone help with specifics?
    So far
    Switched small programming toggle switch down ( hopefully on)
    Selected program button on right hand side (no lights)
    Any advice much appreciated.
    PS my machine a little different in button layout than provided manual.
    Thanks in advance
    Feb 2010
    46
    Should be straight forward.
    1. Turn programming toggle switch on.
    2. Press and hold the programming key on the left group , the lights will flash one its in programme
    3. Pressing the button you wish to programme will start dispensing , press again once you have your desired volume.
    The light on that key should now be out as its now programmed , you can then repeat the other buttons as you wish.
    4. Press the programme key again to exit programming.
    5. Turn the toggle switch back off.
    If all of this doesnt work and the light flashes during dispensing then its likely you have a faulty flowmeter.
    chokkidog likes this.
    Feb 2009
    239
    Wega is right to left. The only machine in the CMA family that the master is right hand group
    Quote Originally Posted by nzcoffeetech View Post
