Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Timbosaurus
Thread: Timbo's 1st restoration - La Cimbali M20
    Mar 2015
    50
    After all of the sweet-talking of Cimbali's on here (admittedly mainly from JavaB, and Java "has an unhealthy thing for Cimbali's" phile), I took the risk and made the BRILLIANT (ie: really stupid) decision to win an old M20 on ebay.
    It was local, a good price and complete, but it's obviously done it's fair share of work and had a few leaks in it's time. It was pretty grubby under it's clothing, but after a few checks and a good clean of the group head, it made a decent coffee. I'm coming from a 6910, and while I was expecting a huge difference in some ways, I wasn't expecting such a huge difference required to HOW to prepare for a shot and steam the milk. So unforgiving, and I have a lot to learn The first thing to learn probably should have been "why an 11L boiler HX machine is not a sensible home espresso machine"....
    Anyway, here are some shots of the condition as it stands, and I've received a bunch of spares from coffeeparts.com.au to start the resto (damn they are quick!).
    Timbo
    magnafunk likes this.
    Mar 2015
    50
    Things that seems to work OK.
    - Both steam wands (but have bought new o-rings/seals etc anyway)
    - hot water wand (but have bought new o-rings/seals etc anyway)
    - Manual fill
    - Auto fill (when the level sensor is bypassed)
    - HX and group bits
    - Seems to have a new over pressure valve and anti-vacuum valve fitted
    - Sirai pstat looks newer that the rest of the machine, but maybe it is just in a cleaner part of the machine
    - wiring is in good shape
    - procon rotary pump works (but does show signs of previous leaks)
    - boiler doesn't seems to leak (but also shows signs of previous leaks, so I have new gaskets for the rebuild)
    Things that need work
    - Chrome on steam wands is not good, so trying to work out whether to rechrome or replace... either way will cost a lot
    - level float (I'm hoping it's just scale, because they're not cheap either!)
    - the pressure gauge (the pump side is OK, and while the boiler side does reacts correctly, it sits on half a bar when cold and about 2bar when hot)
    - the frame needs a full clean/strip/paint and the stainless needs a good polish
    - most of the knobs are floppy or broken
    - many of the gaskets and connections show evidence of leaks.
    - the rotary pump (made in australia apparently!) will likely need a new o-ring at least
    But all in all, I think it should be a good base for a resto.
    One thing i was wondering about was the material for the boiler... I was expecting to see an oxidised copper boiler like many machines on here, but this one looks more like an extruded alloy tube with a plate welded at one end, and a case alloy plate bolted at the other. Is this a higher/lower cost alternative to a copper boiler, or is it just that machines from different eras used different materials?
    Timbo
    Mar 2015
    50
    So far, the dates i can get from the printing on some of the parts are 1989/1990, so I'm guessing this is of 90/91 vintage.
    The rating on the machine is something like 6.3kw, but I've measured each element at 4.3A @ 240V from cold. Given the pump is ~150w, it seems to be more like a 3.2kw machine. So would the ratings on the machine assume a higher voltage across the elements (eg: 380V) to come up with the 6.3kw total? or should I assume that the elements have been swapped for smaller ones at some stage?
    Timbo
    Senior Member magnafunk's Avatar
    May 2014
    East Kimberley
    546
    According to the parts list on coffeeparts the element should be 3750w, the 3 group takes a 5790w element which seems more in line with the 6.3kw rating. Perhaps the data plates were switched at birth?
    Mar 2015
    50
    Hi Magnafunk,
    When I picked up the machine it was fitted with only a 10A plug, which scared me witless given the 6.3kw rating! I disconnected 2 of the elements for all my testing (to be safe), but now that i've measured it at 4.3A per element, I'm comfortable running it on a 15A circuit.
    Here is the plate which seems to line up with the boiler ID, and clearly says 6.3kw. I guess it'll always just be a mystery...
