Hi guys,
I finally got around to plumbing in the Pro 700.
So it's now running off mains, and then through a 3M Filtration setup that has a 350kpa Pressure Limiting Valve in line.
It all seems to be running nicely, but the Profitec manual indicates that the maximum input pressure should be 2 Bar (200kpa). The gauge on the machine is reading 3.5 Bar (as expected from the 350kpa PLV).
Is this going to be a problem? Most of the filtration setups seems to run a 350kpa PLV. It doesn't seem that lower PLV's are commonly available?
Thanks for any advice on this one.
