Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By sprezzatura
  • 1 Post By Logga
Thread: Bezzera Mitica Top
    Senior Member Logga's Avatar
    Mar 2010
    Napier, New Zealand
    328
    Bezzera Mitica Top
    Hi there, I have a Bezzera Mitica Top and I'm using the water tank and sometimes when I'm using it it stops and the orange light goes out, then a couple of seconds later it comes on again, this can happen when it's on and I fill the tank up or when I'm pulling a shot.
    Any one had this happen before.
    Grant
    Senior Member sprezzatura's Avatar
    Dec 2013
    Hervey Bay, QLD
    930
    Hi Grant, sounds like your water level sensor isn't happy. It can act intermittently if the tank isn't secure in its clips and/or the female spade connector is loose, off or corroded. Turn the machine off, unplug it, remove the tank, examine the screws on the left and right (secure), reinstall firmly ensuring its securely clipped in and refill with water.
    Plug into power point, turn on and see if this helps. There are some other things to check but they involve electrical diagnosis.
    Dimal likes this.
    Site Sponsor
    Aug 2006
    929
    Agree with spressatura, check the sensors from the water tank
    Regards
    Renzo
    Mar 2010
    Napier, New Zealand
    328
    Quote Originally Posted by sprezzatura View Post
    Hi sprezzatura, had a look and it seems to of been the two screws that hold the bracket that holds the tank. all good so far, thank you for the help.
    Grant
    sprezzatura likes this.
    Dec 2013
    Hervey Bay, QLD
    930
    I like that function of the Bezzera prosumer machines. Some machines use a weight-activated switch but I like the conductivity sensors.
    Oct 2015
    19
    I just got a Mitica Top too, and remember reading something in the manual about it switching off if there is low water. Perhaps take a look at the manual and see if something there rings a bell.
