Results 1 to 11 of 11
Like Tree5Likes
  • 1 Post By ozscott
  • 1 Post By MrFreddofrog
  • 1 Post By danyboy
  • 1 Post By rrm
Thread: Need Brass Nut for pipe fitting
    Jun 2006
    BRISBANE
    1,998
    Hi all, I have a copper tube from the boiler to the flow meter on my FAEMA Due that has a split nut on the boiler end. I had tightened it too much...
    I cant see the fitting on Coffeeparts. I am happy to cut the copper and re-flare the tube and just use a new brass nut.
    I will try Pedro on Monday but anyone have any ideas for a nut?
    Jun 2006
    BRISBANE
    1,998
    If i search for Nut on Coffeeparts there are pages of hits including brass ones....he should have mine there somewhere.
    Dimal likes this.
    Aug 2015
    Perth WA
    461
    Have you tried the plumbing section of Bunnings? They seem to have heaps of that kinds of stuff. Not sure if they'll have the size you need though.
    ozscott likes this.
    Jun 2006
    BRISBANE
    1,998
    I have from Coffeeparts ordered a 3/8th BSP suitable nut that looks ok. I havent tried Bunnings...not sure if they run as small as 3/8th.
    Aug 2015
    Perth WA
    461
    Alternatively try a specialtist plumbing store like Reece, plumbing section not bathrooms. That's also have looks of stuff.
    ozscott likes this.
    Oct 2011
    Brisbane
    37
    Hey ozscott,
    You can try ebay, as there are some nuts and other plumbing type equipment.
    Alternatively, I see you are in Brisbane, you can try Anzor, they are in Acacia Ridge (just google Anzor, they have an online product listing).
    ozscott likes this.
    Jun 2006
    BRISBANE
    1,998
    Hi good people. The pipe was a bit old and brittle to reflare and split...who would have thought after 35 odd years! I dont think i can purchase the whole pipe and fittings already made up ??...so does anyone know a good place in or around Brisbane where i can get a new pipe bent up? (I have the fitting for the flow metre end from the old pipe that can be cut off and braised onto the new pipe and i have a new nut for the boiler end. Pic of the good pipe from the left group attached.
    rrm
    rrm is offline
    Mar 2015
    49
    Any refrigeration mechanic would totally at home with this work, and a lot plumbers with oxy gear in their trucks.
    Or buy yourself a mapp gas torch and some 20% silver solder and do the job yourself. Ideally with brass you should a SS flux. Rothenberger make a good tool,
    1/4 inch copper can be bent by hand using any available object as a former provided the copper is well annealed before bending. To anneal the tube heat to a cherry red and allow to cool naturally.
    Best of luck
    Jun 2006
    BRISBANE
    1,998
    Thanks mate. Should i have heated the pipe before using my flare tool?
    Jun 2006
    BRISBANE
    1,998
    I have a MAP and silver solder.
    rrm
    rrm is offline
    Mar 2015
    49
    It's always a good idea to anneal pipe prior to flaring.
    Looking at the image, I'd be tempted to aneal the entire pipe, trim the end and flare again, with a little careful reshaping it may be OK.
    Dimal likes this.
