Results 1 to 7 of 7
Like Tree1Likes
Thread: ECM Mechanika Profi - Squeaky levers
    Jan 2016
    7
    I have ECM Mechanika Profi with levers. The levers became quite squeaky. Do I need to grease them? If so, what kind of grease can be used?
    Can the group lever be greased as well? Seems to be squeaky too, especially after back flashing with machine cleaner.
    Apr 2016
    47
    Hi,
    This also happened to me during backflushing (note that my ECM is less than 2 month old). However, in my case, the lever started to work normally after the backflushing process was done. I suspect that in my case.
    Try to pull the lever a couple of times, and see if the squeaky probably can disappear.
    Member nathanharley's Avatar
    May 2015
    Perth
    68
    Hi daro, i'm not sure about the levers, but the group lever (cam and shaft) is greased with any food grade lubricant, I use molykote 111. Chemical back-flushing does dissolve away the lubricant over time, so regular lubricating is advised.
    nate
    Jan 2016
    7
    Do you have Profi version? If so, how are the valves levers? Do they operate smoothly?
    We got a brand new ECM Automatika Profi at work a few weeks ago, and the levers are very smooth, compering to my machine at home.
    May 2015
    Perth
    68
    No I have an older Barista model mate.
    Jan 2016
    7
    Hi nate, thanks for the info. I'll try to get some food grade lubricant and will give it a go.
    I guess I could apply same lubricant on the balls of the steam/hot water levers too.
    May 2015
    Perth
    68
    Quote Originally Posted by daro View Post
    No worries, yeah i would give it a go, cant hurt surely?
    Nate
