Results 1 to 3 of 3
Thread: Recommendation Lever coffee Machine
    Aug 2016
    1
    Exclamation Recommendation Lever coffee Machine
    I am seeking some advice-knowledge and a recommendation for 2 group levered espresso machine- gas powered.
    I have a small business, And I am planning on venturing out to the streets as well and set up a portable coffee cart that doesn't have to be powered by the 240 volts.
    I am seeking a 2 Group machine to keep up with sales
    So far I have founds this be quite overwhelming when looking online and overseas but also elusive when looking at machines and availability in Australia.
    From looking on the internet I found the vintage Gaggia lever espresso machine being used on a coffee cart.
    Here are the other machines I have looked at.
    Bezerra B2013 AL 2GR, Fracino, Ozzo, Bosco, Vasari - VASARI 2L
    I would appreciate any recommendation and knowledge these machines or any others
    Feb 2013
    280
    I've noticed the gas Fracino 2 group seems to be one quite commonly used in portable applications where electricity use needs to be minimised.
    But it's usually the pump version rather than lever. A 2 group lever will be slower than a 2 group pump machine. Without electricity, you'd also have to remember to do manual refills.
    I'd visit your council - as they will probably insist of having a powered fridge for milk and hot and warm water for washing up and hands respectively. You'll want to run a powered grinder as well.
    Apr 2008
    Victoria, Australia
    2,095
    Izzo Valchiria | Talk Coffee
    Izzo by Gruppo Izzo | Talk Coffee
    +1 to simonko's above you will have to deal with inlet water pressure (i.e run a flojet??) as well as other power needs.
    You can run your gear off deep cycle batteries and an inverter. Cimi also have gas fired conventional (e-61) machines.
