Results 1 to 9 of 9
Like Tree1Likes
  • 1 Post By onewheel
Thread: ACS Vesuvius - Power Requirement
    Jan 2007
    32
    Hi Fellow CSers,
    Does the ACS Vesuvius require a 15 Amp GPO? I'm currently currently considering this as my next upgrade. Thanks.
    Jason.
    14,665
    It's 10A Jason
    Jan 2007
    32
    It's 10A Jason
    Thanks Chris. That does make things a whole lot easier. I'm guessing not all 2300W is drawn at the same time? Calculate current draw for 2300W works out to be
    2300/(0.8 x 230) = 12.5 Amps.
    16,870
    No need to use a PF of 0.8...
    90% of the load is resistive.
    Jan 2007
    32
    Thanks for pointing that out Mal.
    Assuming 100% resistive load, the power factor would be 1. Making the current draw at exactly 10 Amps. Would that be correct?
    Dimal likes this.
    14,665
    The machine is protected by a 10A fuse.
    Jan 2007
    32
    Thanks Chris. Thanks all I need.
    16,870
    Quote Originally Posted by onewheel View Post
    In a perfect world, yes...
    Dec 2008
    149
    Keep in mind the Vesuvius remains in standby mode if you plan on using the built-in 7 day on/off timer. In which case it wouldn't hurt to add a little surge protection. I'm running one of these between my Vesuvius and the GPO (Thor C2 - Smart Filter Duo) - better than nothing I suppose...
Tags for this Thread
