Results 1 to 3 of 3
Like Tree2Likes
  • 2 Post By Dr_Dave
Thread: Alex Izzo Leva owners
    Jun 2016
    26
    Quick question.
    How do you change the temperature using PID? The manual is rather difficult to decipher. I was going to try and press the buttons but I figured I could ask and get a precise answer. Thanks in advance.
    Mar 2007
    The Hamptons
    290
    Hi,
    Hold both buttons down at the same time and wait until some writing comes up "Pr" (from memory), then push either up or down button until you get the temp you want, then take fingers off. If its up and the boiler is heating you will see a little dot in bottom right hand corner of the screen. If you want it temp down you will have to wait until it cools. You can obviously run hot water out the water arm and wait for it to refill and cool that way
    Hope that helps
    Dave
    Dimal and shortblackman like this.
    Jun 2016
    26
    Easy. I'll give it a go. Thanks.
