Results 1 to 36 of 36
Thread: La Pavoni,..  just like Sparky!
    Jul 2007
    65
    Hey Guys.... Post number 1 from me!
    I have been enjoying rather acceptable (read better than most cafes) espresso from my humble little Napolitana Combi for a few years now. Was seriously considering the upgrade to La Scala Eroica in a couple months,... then - THIS! I just bought a La Pavoni Bar 2S (or possibly 2T - Im guessing at the model!) very similar to Sparkys new one off flea-bay! Paid $1500, including the La Pavoni Zip grinder!!! I thought... can I go wrong?!?!?!
    SO,.. what exactly have I got myself in for?!?!?
    I know I have to plumb it in,.. probably have to put in a new power point for the bugger too... I plan to give it a clean up when I get it, not sure how long it has been in storage for.... but it looks clean, and certainly will keep my caffine addiction at bay!
    Any tips, tricks etc?!?!?
    Sparky - did most of coffeeparts Pavoni bits fit your beasty?
    Looking forward to the response!
    Cheers!
    Mark
    Jul 2007
    87
    Re: La Pavoni,.. *just like Sparky!
    You need to have good friends who are prepared to help you clean it up.
    I wonder where youll find those...... ;)
    Almost sorry I pointed you to that link now. If only Id had the room in my kitchen to house it........ only joking mate. Its just the jealousy talking now :P
    Jul 2007
    65
    hahahahaha.... you know youll enjoy the coffe just as much Caff....
    Besides, its going to take a while to match your shot skill from the Silvi!
    604
    What a pretty machine- look at those group heads- serious looking grinder there!
    Brett
    3,498
    Re: La Pavoni,..  just like Sparky!
    Hi Zedd,
    Great looking machine for sure. With a little luck you might only need new group seals and a few other low cost. easily replaceable bits.
    Yep plumb her in ..... and you will need a special power run (or reduce the number of elements in the heater).
    Id probably do a descale unless it has been used on a regularly serviced water softener....
    And then sit back and enjoy great espressos.... lots of them!!
    Sep 2006
    104
    Yup, It isnt as much effort to get it hooked up as it may seem, but if its had a hard run a descale may be in order... but just hook her up, and try it out first... who knows, it may be good to go as is!
    Cheer, Mark
    Feb 2005
    3,096
    Welcome to the Extreme end of town, Zedd.
    A diabolical purchase! Seriously, she looks good, and hope the innards are ditto.
    Already jealous of the steam wand on both sides. I used to think that was such a redunant feature... but now that I have to lean across my machine to reach it in its new position, I can see they make sense. But I digress.
    Hope La Pavoni starts earning its keep with a minimum of effort.
    -Robusto
    Apr 2005
    1,176
    Hi Mark. Nice find. Im pretty happy with my machine, but am still tweaking it. The coffee parts pieces work for the most paort. I ended up replacing the upper and lower valves, not just the rubber seats, and found that the threads on the valve rods were different, so I had to get the entire part. I got the cheapest option, which didnt fit my machine, but used a lathe to cut it back to the correct size. I was on the phone a bit with Pedro to sort out what was what, but they had all the parts I needed.
    I had to add a one way valve to the input of the pump to prevent back flow into the pump, which may have killed one of my pumps.
    Im a bit busy now, so Ill get back to you.
    Mark.
    Jul 2007
    65
    Hey,.. * just wanted to thank everyone who replied!
    I pick her up tonight, but then Im actually going away for august with work,..which is unfortunate. *I wont get stuck into her until I get back.
    Im excited to even wipe down her gleaming chrome though! *let alone the prospect of espresso flowing from her portafilters!!
    Feb 2007
    242
    Im sure someone here would be happy to look after her for you Zedd while youre out of town ;)
    Jul 2007
    65
    Well... I picked up the new girl(s) last night. :)
    Man, that grinder is a MONSTER,.. total overkill for home,.. but I LOVE IT! It is SOOOO quiet compared to the Lux built into the Mokita Combi,... cannot wait until its my only grinder. The doser floors wipes SO clean,.. impressive. I wasnt able to work the grind adjustment in the 5 minutes I was fideling last night,.. it might be gunked up.
    The Pav is rather clean, inside and out. (Ill endeavour to get some pics of her tonight, and try to post them tomorrow! I know how all you tech heads love the pics!!! :))
    I have decided that in the process of bringing her online, I am going to change the steam wands as well as her group head seals, and perhaps the orings and seals in the valving of the E61 group heads. Shower screens are spotless! I have one slight concern... they didnt drain the boiler!!!! :-/ Both steaam valves, and the water tap were left open, but the boiler still has standing water..... so shes going to need a real good flush!! Im going to drain off some water tonight into a glass and inspect it for look and smell. Alge is my concern.
    I am suprised at the lack of buildup inside her though,.. and even the drain tray and the little black box are perfectly clean.
    Shes stamped as a Bar 2T,.. and the year of manufacture is 2000!!!!!
    Pretty darn excited... shes SOOOO gorgeous!!!!
    3,498
    Quote Originally Posted by Zedd link=1184556429/0#10 date=1185226175
    That is a GOOD sign....
    If they drain the boiler, and scale etc dries out and can come loose..... so a boiler with water in it keeps that all in place....... even a little scale in a dried out boiler can cause a problem necessitating a descale.
    Sounds like you have a real great buy..... and so recently manufactured as well....
    Congratulations!!! :) :)
    Jul 2007
    65
    WHOA!!!! Cool!!!!! :D
    That is some damn good news JavaB!! Thanks!
    The people who sold it to me really had no clue! They owned a bookshop cafe, and had no idea baout the coffee making side of the business at all. The employed a barista who looked after that entire side of the business, and he obviously cared about the equipment, and had pride in his work. He had them paying for a service technition to come in and service the machine MONTHLY! Now,.. I may be wrong, but I would think that monthly service would only require a good flush/clean (stripping group heads etc),.. I wouldve thought that that would be something that could easily be done by the barista himself? Am I totally wrong for a commerical setting?
    3,498
    Zedd,
    Most cafe owners wouldnt have a clue on how to do even the most basic of services..... neither would most baristas.... so they call in the professionals... (and it is a tax deduction for them as well ;))
    Yes, they could do it themselves (as we do)..... but in any event - its good news for you!!! :)
    Feb 2005
    3,096
    Dont see that algae could be a problem -- the boiler is sealed from light.
    A mere flush may well see your bright new toy ready for business.
    Fingers crossed,
    Robusto
    Jul 2007
    65
    Very good point robusto!
    My fears have subsided!
    When I return, Ill arrange power and plumbing... * then Ill change the steam wands (theyre a little marked in the chrome, and really not expensive!), and the group seals. *Ill give everything a clean... especially the group heads etc...*then fire her up. *Ill do a back flush, and a couple full boiler flushes... * *then brew a shot... *or ten!!
    SOOOOO looking forward to it!
    Ill still take some happy snaps to post tonight!
    M. *
    Jul 2007
    65
    Pictures of my Pav!
    OK,.. *I promised pics... here some are!
    (I hope these work out!)
    The machine,.....
    [img]<img src="http://i13.photobucket.com/albums/a273/zeddrums/Coffee/LaPavoniCoffeeMachine004.jpg">[/img]
    The Showerscreens - SPOTLESS!
    [img]<img src="http://i13.photobucket.com/albums/a273/zeddrums/Coffee/LaPavoniCoffeeMachine007.jpg">[/img]
    The huge boiler and inards:
    [img]<img src="http://i13.photobucket.com/albums/a273/zeddrums/Coffee/LaPavoniCoffeeMachine008.jpg">[/img]
    Procon pump and plumbing...
    [img]<img src="http://i13.photobucket.com/albums/a273/zeddrums/Coffee/LaPavoniCoffeeMachine009.jpg">[/img]
    The Zip Grinder....
    [img]<img src="http://i13.photobucket.com/albums/a273/zeddrums/Coffee/LaPavoniCoffeeMachine015.jpg">[/img]
    Like I said,.. hope they work out!
    Mark.
    Jul 2007
    65
    hmmm... * sorry theyre a little large, arent they! :-/
    Senior Member Lizzie's Avatar
    Feb 2007
    Bridport, Tas
    1,151
    you lucky so-and so!!!
    you are going to have soooo much fun.... ::) ;)
    L
    Dec 2004
    Earth!
    16,336
    Sorry Zedd, but no pics came through.
    Java "Peeking for the pics" phile
    Feb 2007
    Bridport, Tas
    1,151
    :-???? the pics are there, Java...
    Dec 2004
    Earth!
    16,336
    Quote Originally Posted by Lizzi link=1184556429/15#20 date=1185347400
    Hhhhmmm....Not for me.
    OK,.. I promised pics... here some are!
    The machine,.....
    " alt="" title="" border="0" />
    The Zip Grinder....
    Mark.
    Thats all I see. :(
    Java "Still peeking" phile
  23. #23
    Jul 2007
    65
    hmmm... pics are there for me too!!!
    See if you can see this:
    mod edit use [img] url here [/img] to load your pix instantly ;)
  24. #24
    3,498
    Quote Originally Posted by Javaphile link=1184556429/15#21 date=1185348344
    Thats all I see. :(
    Me too Java....
    Must be a Java thing ;D ;D
  25. #25
    Jun 2006
    BRISBANE
    2,004
    I can see the pics and they are very nice mate. I like the extra long steam wands!
    Dec 2004
    Earth!
    16,336
    OK, to avoid messing up the original post Im going to make some mods to the links in the original post and repost it here.
    ------------------------Original post with mods made to the links------------------
    The machine,.....
    The Zip Grinder....
    Mark.
    ------------------------------------End of original post-------------------------
    Lets see how this works. :)
    Java "da Modifier" phile
  27. #27
    Jun 2006
    BRISBANE
    2,004
    Mate I just re-read your first post on this thread....seems like great value ...well done.
  28. #28
    Jul 2007
    65
    has that fixed it for you java-bes a computer wizard-phile?!!!?!?
  29. #29
    3,498
    Thanks Java....
    That is one really nice looking machine there Zedd...
    Not much work required on that one....
    And so many "Oh so good" espressos to look forward to.
    Congrats :) :)
  30. #30
    Jul 2007
    65
    Thanks for the words Lizzi and Ozscott too!! ;)
    I just cant wait to fire her up... but it wont be for over a month, as Im going away! :(
  31. #31
    Jul 2007
    65
    Thanks JavaB
  32. #32
    Dec 2004
    Earth!
    16,336
    EEK!! Those are some huge pics. Might I suggest you resize them so you can see the entire pic with-out having to scroll back and forth.
    When using the img tag put only the addy of the pic between the tags and nothing else, i.e.: (img)http://picture_addy_here(/img)
    FYI The square brackets have been replaced with parenthesis so its visible. Use the square brackets in actual usage. :)
    Java "Parenthetical" phile
  33. #33
    3,498
    Zedd....
    Your new tamper will get lost in the midst of all that bling.....
    But it will help you make great espressos (even if it doesnt get noticed ;))!
  34. #34
    Jul 2007
    65
    Hehehehe... not wrong JavaB,.. but the tamper will always have pride of place!
    Javaphile,.. Thanks for the tip! ;)
    Whats a simple way of resizing the pics?? :-? I mean, I know I could open the photos on my machine, shrink them in photoeditor, upload them to photobucket again, and repost again,.. but is there a simpler way? That wont remove the ones that are already there will it? Maybe Photobucket have a way I can resize directly... hmmmm... Ill go look. :)
  35. #35
    Jul 2007
    65
    OK!!! I got them resized... sorry about the stuff around!!!!
    Posting pics in web forums is all new to me!!!! ::)
  36. #36
    Apr 2014
    Hampton
    1
    Hey There Guys,
    Ive just picked up a LaPavoni Bar T S2 for restoration.
    And, Ive been trolling through old posts looking for people doing the same with these machines and came accross your discussion, sorry I know it was from 2007!!
    I've found I need a new Boiler as one of the heat exchangers has split.
    Do you guy's know where I might find a serviceable used one, or even a dead machine with a serviceable boiler?
  1. Replies: 2
    Last Post: 6th January 2009, 09:45 AM
  2. Elektra Micro Casa   vs   Sunbeam EM0480
    By mr_homer in forum Grinders
    Last Post: 14th September 2008, 09:26 AM
  3. Perth Barista Jam   8 June 2008
    By tanghy in forum General Coffee Related...
    Last Post: 16th May 2008, 10:27 PM
  4.  Elect Mic Casa or La Pavoni Pro or Gaggia A
    By Latte_Lover in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st February 2008, 08:06 AM
  5. Alternate Steam Wand for Imat Mokita... Sparky?
    By Dimal in forum Brewing Equipment (non-machine specific)
    Last Post: 12th September 2005, 12:22 AM
