Results 1 to 10 of 10
Thread: Hissing coming from dual boiler when at temperature.
    Apr 2018
    4
    Hi,
    My dual boiler hisses on occasion, when at temperature. Is this normal?
    Doesn't happen often but when it does it can be stopped by a quick purge of the steam wand.
    It's coming from the top/inside the machine, not at the steam wand or valve.
    Thanks.
    Dec 2009
    SYD
    610
    Could it be the false pressure release on the steam boiler?
    This could occur if you draw off a good amount from the hot water wand (eg making long blacks or tea).
    Cold water rushes in and the water goes below boiling. Then you get hissing until the fales pressure is bled as the machine passes back through 100C.
    Apr 2018
    4
    It happens when the machine is dormant between coffees. Only noticed it a couple of times this week, but it's when the machine has been on for a while and hasn't made a coffee for at least an hour.
    Nov 2017
    Maddington, Perth. Wa
    1,107
    Take the top off and have a look
    Aug 2010
    89
    Most likely steam from safety valve. Could be faulty valve or relay. What machine is it?
    Dec 2009
    SYD
    610
    How long since it was last serviced?
    Nov 2017
    1,107
    I see coffeeparts has anti-vac valves that plumb into the drip tray. Upset i didnt get myself one of them.
    Apr 2018
    4
    It's a rocket r58 and it's still within warranty and never been serviced. Using filtered water which has been tested and is very soft. Just not sure if I can open up the machine without voiding warranty?
    Apr 2018
    4
    What does the relay do?
    Dec 2009
    SYD
    610
    Quote Originally Posted by CirCoffee View Post
    Yes you can definitely open it up for inspection. That doesnít void warranty any more than lifting the bonnet of your car.
    However if you stuff something in the process of poking about trying to fix it yourself then you could have issues.
    Given itís in warranty, maybe have a chat to the dealer.
