Results 1 to 12 of 12
Like Tree15Likes
  • 1 Post By Martino
  • 3 Post By Martino
  • 1 Post By CafeLotta
  • 5 Post By noidle22
  • 1 Post By Martino
  • 2 Post By noidle22
  • 1 Post By noidle22
Thread: Bezzera Duo DE Dual Boiler
    Member Martino's Avatar
    Mar 2016
    New York
    77
    I have just seen this machine starting to hit the US market. Some have it in stock, others have it coming in but since its so new here, I can't really get much info on it aside from reading specs. Anyone here know this machine? I've attached a pix. Before seeing this, I was about ready to pop for the ECM Synchronika but I like some of the features of this machine and since its a volumetric machine, it makes it easier for others in the house to use. It offers many of the features of the machine I currently have and that we like. It's being advertised for US$2,750. They use their own version of the E61 brew group with an electric element PID controlled heater and two more PID's for the brew and steam boilers.
    Is Bezzera a reliable brand? I don't particularly like early adoption with products that have electronics in them
    If you want to read more about it, here's a site where you can.. https://www.wholelattelove.com/bezze...,1C40GF,9NDV,1
    zeezaw likes this.
    Jun 2012
    Melbourne, Vic, Aust.
    1,311
    Quite like the look of the Bezzera Duo MN which is in the same family as the DE. The DE is volumetric and has the Bezzera electrically heated grouphead. The MN has an E61 grouphead and no volumetric brewing buttons. Appears like we do get the MN version here as well as the similar Bezzera Matrix clear sided version with the added light show. Been out a little while now but worth a mention I thought.
    Bezzera Matrix and Duo MN - https://www.youtube.com/watch?v=q-prKcL5H-4
    Internal tour - https://www.youtube.com/watch?v=UoDRdSXV06U
    Just noticed that this thread should really be moved into the $3000+ machine category.
    Last edited by CafeLotta; 14th May 2019 at 10:15 AM. Reason: Correction MN version availability
    Mar 2016
    New York
    77
    Quote Originally Posted by CafeLotta View Post
    Quite like the look of the Bezzera Duo MN which is in the same family as the DE. The DE is volumetric and has the Bezzera electrically heated grouphead. The MN has an E61 grouphead and no volumetric brewing buttons. Doesn't look like we get the MN version here but rather the similar Bezzera Matrix clear sided version with the added light show. Been out a little while now but worth a mention I thought. Puts it at a similar market price point as the classy Izzo Alex Duetto IV Plus which has the added feature of pre-heating water entering the brew boiler.
    I was on the fence in terms of whether to go with the Duo DE or the ECM Synchronika. I was in Germany last fall and finally had the chance to see both machines and use them at two different places in two different cities. It became clear to me after spending time with them both that for me, the Synchronika was the better machine. Why? Well, I really wanted the volumetric feature of the Duo DE because I had grown used to that by owning a few Breville Dual Boilers over the years but the quality of the Duo DE's I saw were just not at the $3K-ish level. LCD failures, more flimsy than the ECM and there is something to be said about he tried and true E61 group. The Duo DE is new and I guess they need time to work out their issues but having that LCD panel adjacent to the boilers isn't doing it any favors.
    So, upon returned back home to the states, I bought the Synchronika and am very pleased with it. Built like a tank, consistent, quiet and reliable. I'll have to put this machine in my will :-)
    CafeLotta, DaveD and level3ninja like this.
    Jun 2012
    1,311
    Does sound like there are a few things that might need to be improved. The additional electronics in the Duo would no doubt increase it's vulnerability to failure when compared to a simpler designed machine. The thread on the link below has someone commenting on moisture forming on the inside of the screen. I've never understood why all manufacturers don't vent moisture from the relief and vacuum valves to the drip tray rather than some allowing it to vent internally. Might be the reason for the screen issue.
    https://www.home-barista.com/advice/...uo-t51488.html
    Dimal likes this.
    Mar 2012
    Bathurst
    1,229
    One of the first things I did to my Matrix was install a anti-vac with a return line to the tray.
    I could see the moisture condensing on the insides of the panels.
    To be honest, the machine has a lot of niggling faults. Listed below:
    1. Anti-vac vents in to the case
    2. In-tank water level sensor is far too sensitive. Triggers to fill with over a litre left and cuts the machine off during a shot if it triggers.
    3. LCD screen and main power light stays on full brightness when on standby.
    4. Pump pressure gauge is useless, bounces from 5-10 bar during the shot and responds incredibly slowly.
    5. Pump adjustment is accessed from the base of the machine. Pretty hard to access when the machine is installed.
    6. "Adjustable pre-infusion" isn't pre-infusion, it's just wetting. Allows a small amount of water onto the puck, closes the solenoid and keeps the pump running but no line pressure onto the puck.
    7. When switching on from standby, the machine doesn't indicate the current boiler temperatures, it displays the temperature that the machine was at when last switched off.
    My machine has also started turning itself on at sometime during the night. I have the auto on/off timer on and the set time hasn't changed but a few times I've woken up early morning and the machine is already on.
    Jun 2012
    1,311
    Always good to get unfiltered feedback from an owner of the machine, especially when it's from a longer term CS member.
    Feb 2019
    27
    Mate I feel for you, those issues are not what you expect to have when buying a $4000+ machine.
    Mar 2016
    New York
    77
    Quote Originally Posted by noidle22 View Post
    noidle22,
    I saw some of those issues when looking at the Duo DE in Germany....let me first go on to say that the Duo DE is the machine I really wanted due to its features but wasn't willing to put up with potential issues, especially after coming from the Breville DB and all of its issues and the fact they wouldn't sell me replacement parts. I wanted reliability this time around.
    Ok, so the ECM Synchronika has a few irks of its own, for me, they are:
    - The pump pressure adjustment is also on the bottom of the machine, however, I set it initially and have never had to touch it again
    - There is no "pre-infusion", there is just wetting unless you hard plumb the machine, then you would have line pressure pre-infusion. Mine is currently using the internal water reservoir so all I have is wetting
    - The in tank low water sensor pisses me off, it will simply shut the steam boiler off once it triggers, .. no warning. I know this is pretty typical on E31's but being typical (common) you would think the mfg would have installed a warning light, sight window or someway to prevent it from simply turning off in the middle of a brew.
    That's it, all pretty minor really and none that cause a reliability or consistency issue. The lack of electronics is in fact the beauty of the Synchronika. It just works, day after day, just works. I am learning to check the water reservoir level more often and am thinking of how I can install some sort of low level warning cause the wife won't let me drill a hole in the counter to run a water line
    Here's a pic.. . .Yeah I know, they all look alike
    338 likes this.
    Mar 2012
    Bathurst
    1,229
    Quote Originally Posted by Martino View Post
    I run my Matrix on mains pressure now and the preinfusion still doesn't work, it's just wetting.
    It's the way the machine operates. The group solenoid opens breifly to allow water onto the puck but the machine starts the pump as soon as the shot button is pressed. The group solenoid then closes but the pump stays on, diverting water somewhere other than the group. There's a small spurt of water into the tray when this happens but not a constant flow which means the pump isn't just directing water into the tray. It isn't going onto the puck though so it's going somewhere.
    I can't see why Bezzera didn't program the machine for line pressure preinfusion. The hardware is all there, it just needs to be programmed properly. I did speak to the importers about this briefly but there was no indication that Bezzera were planning to do anything about it because as far as i could make out, i was the only person to have called them and brought up the issue.
    My main issue with this was that the product brochure clearly states "Settable pre-infusion" when the machine clearly can't perform pre-infusion. If they had said "Settable puck wetting" or similar then that would have been clearer.
    CafeLotta and 338 like this.
    Mar 2016
    New York
    77
    You have reminded me why I didn't buy the Duo DE. I now remember watching a video on its features and saw how 'pre infusion" didn't work along with a couple other oddities. However, I still wanted the machine at that point, it wasn't until my reliability issues were confirmed when I saw faulty LCD displays on the demo machines in Germany that I put it all together and made my decision against it and for the ECM. Ok, so we each made our buying decision and now have to live with our machines. Of course, you can try to sell it and get something else but for me, I'm happy and will stay with the ECM.
    Mar 2012
    Bathurst
    1,229
    Yeah I'm going to stick with it. None of the small issues are deal breakers for me really. I hope that there is a remedy for the pre-infusion at some point in the future.
    One thing I thought of yesterday after writing my reply, as I said, the first mod I did was to install a vent to tray anti-vac valve. I've not had any moisture behind the LCD problems or LCD problems at all but a surprising number of people seem to have.
    This would seem to point to the anti-vac venting into the case as being the probable cause of this now. I would hope that Bezzera can take this on board and include a vent to tray anti-vac on the next revision of the machine. It's ridiculous that they didn't include it as standard to start with really when you consider the price of the machine.
    Also one other annoyance I have with it, every time I turn it on, the autofill runs for 5 seconds and it seems to top itself up nearly every time I use the steam or a little bit of hot water by running the pump for another 5 seconds or so. I think they need to revise the autofill sensitivity as well.
    CafeLotta likes this.
    Jun 2012
    1,311
    Your comment re: pre-infusion (in addition to the built-in E61 mechanical pre-infusion), had me wondering what the correct definition of this was. As it happened this article popped into my inbox not long after -
    https://clivecoffee.com/blogs/learn/..._hsmi=72657666
    The one thing I believe the animated diagram gets wrong though is that it shows water entering the Pre-Infusion chamber below the cam. My understanding is that the pre-Infusion Valve spring requires 4-6 Bar pressure to open the valve. If a plumbed in machine has adjustable line pressure set to 3 bar, the line pressure won't activate the E61 Pre-Infusion valve so water will have a quicker, more direct path to the portafilter for initial manual or programmed Pre-Infusion at 3 bar. I've seen various Pre-Infusion valve springs available (especially overseas) so imagine you could play around with the E61's native pre-infusion pressure and adjust it down if so desired. For those that haven't noticed it, your brew pressure gauge will show a momentary pause at around 4-6 bar at the beginning of a brew before settling at 9 bar or thereabouts. This is the E61's mechanical Pre-Infusion at work.
    Dimal likes this.
