Page 1 of 2 12 LastLast
Results 1 to 50 of 53
Like Tree65Likes
Thread: My Take On Cremina - From Start To...
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    When asked, Chris (Talk Coffee) told me there was no secret to pulling a shot on the Cremina, "Just follow the instructions".
    For my first Cremina shot, I left the Mazzer Mini E setting as it was for my outgoing Brewtus. 14g of 2 months old CS Decaf Wow tampted to 30kg, almost choked Cremina - took over 60 seconds for the extraction, with me hanging off the lever. Made the result into a surprisingly drinkable cappuccino. Three progressively more drinkable shots later I had her dialled in.
    First impressions - Cremina is very forgiving, no bitterness at all. The ongoing pressure adjustability allowed me to rescue what would otherwise have been sink shots on my Brewtus. Tastewise, there was a smoothing out - no highs, no lows. The nuances were there, but I had to take the time to look for them. Introducing the HG-1 added the hitherto missing body.
    Ps one visitor's reaction to Cremina, "How come you got rid of the big expensive looking one"? My answer, "Ran short of a quid and had to trade down". No point telling them the truth. They already think I'm nuts.
    338
    338 is offline
    Mar 2017
    985
    Thanks for the review, do you prefer the taste of the Cremina?
    Ps love the 'trading down' comment.
    May 2008
    4,209
    I have a 1987 version of the Cremina and has consistently provided the best espresso shots I have made. I find I can use the same grind on my Macap MXK as for my Giotto. 14g is the dose I also use but i don't tamp hard. I get a wider range of flavours from the Cremina.
    My technique is to insert the portafilter loosely, pull the lever up to about 2 o'clock, lock the portafilter in and then raise the lever to the top, pause for several seconds and then pull the lever down until I get about 25ml which is usually before I reach the bottom. I don't raise the lever again to extract more; I have two baskets and the portafilter has been converted into a naked so I'm preparing two double ristrettos each time.
    Paolo, OCD, SanderP and 2 others like this.
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    Quote Originally Posted by 338 View Post
    Early days 338. The Cremina/HG-1 combo doesn't necessarily produce better coffee than my previous machines (Brewtus & Silvia) but what used to be exceptional shots are now almost expected. With ongoing burr seasoning and technique improvements, I'm hoping regular God Shots are in my future.
    Ps the Cremina will, in my experience, turn just about any ballpark grind into drinkable coffee and, contrary to popular belief, no special skills are required. Paired with the HG-1, the sky's the limit.
    SanderP, suvartet and 338 like this.
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    Quote Originally Posted by flynnaus View Post
    Even in the unlikely event that I had the exact same equipment, even the same beans, and was able to copy your techniques to the letter, the "in cup" results could only be subjective. However, your post does present a possible starting point from which to pursue (one variable variable at a time) my own elusive idea of coffee perfection.
    Thanks.
    May 2008
    4,209
    Quote Originally Posted by OCD View Post
    Thanks.
    True OCD. I hope I didn't come across as patronising. I can only describe what works for me but my advice came from the CSer I bought my Cremina from (Paolo), a kind of consensus from study of many online sources and a bit of old fashioned trial and error. It works for me but not necessarily for everyone. We do both have basically the same espresso machine and conical grinders but there are lots of other variables. Perfection is relative.
    RavenMad likes this.
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    Didn't mean to come across as dismissive. I would be a fool to do so - life's too short to keep reinventing the wheel.
    I was conflicted about what to do at the end of the pull. Let go? Hold it down until the drips stop? Go back up for another bite? Questions. I hadn't considered your suggestion to stop before reaching the bottom. Another variable to explore.
    Helpful - not at all patronising. Thanks again.
    Dimal and RavenMad like this.
    May 2008
    4,209
    I keep a small plastic container handy. Once I have finished pulling ~25mls, I then replace the cup with the container and catch the last bit of the shot as I pull the handle all the way down and hold it there until the coffee stream turns into drips, which helps relieve the pressure a little. I keep the container there while I slowly and carefully remove the handle.
    As I am making ristrettos, I don't go back for a second pull ; it usually isn't as good.
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    After a month with the Cremina/HG-1/Lido E setup I feel I've reached my sweet spot, equipment wise - no buyer remorse at all. For my needs (one Lido E ground coffee and two HG-1 ground decaf coffees per day) it's just about perfect. With my previous Silvia/Rocky and Brewtus/Mazzer Mini E setups it didn't matter how consistent my routine was, the results were all over the place. I couldn't nail it down. Now, the results deviate only marginally, which should allow me to perfect my technique incrementally.
    I marvel at how something as basic and unassuming as Cremina, can consistently produce coffee of a standard that I used to only fluke once in a while. Just what is it that Olympia Express got so right? Does anybody even know?
    My missus has forgotten about the initial, admittedly substantial, expense and now reckons it was a wise investment. "Other than the first one or two, you haven't made a bad coffee since you got that thing." From her, that's a ringing endorsement.
    A downside is that people have been asking for seconds, and this is where Cremina falls down - apparently she needs temperature surfing, which I have yet to grasp. Much has been written about the 3rd and subsequent shots, ranging from 'don't do anything, just pull the shot' to 'let it cool for X minutes (with or without a cold wet towel draped over the group head)' even 'cool the portafilter and reinsert for X minutes/seconds...' I've still got a lot to learn - and loving it.
    Btw 'don't do anything, just pull the shot' didn't cut it.
    Conclusion: fine instruments that beg to be finessed and mastered. I liken Cremina to an older Porsche (pre ABS & ESC etc). You don't have to be a Jack Brabham to drive one but it would be up for it, if you ever were.
    Ps my chances of ever fully mastering Cremina (God shots on demand) are slim to none but she is forgiving, and is letting me make damned fine coffee in the meantime.
    Ps 2 before buying Cremina I flirted with getting one of the 'Decent' machines. I was particularly impressed with the developers passion and candour. In the end nostalgia won out. I love technology as much as the next guy but it's all moving a bit too fast for me. Cremina takes me back to a more leisurely past.
    Feb 2011
    371
    Thanks for sharing your experience OCD. The HG-1 probably takes half the credit as it removes grind inconsistency from the equation (eliminating grind retention and measuring the coffee weight will solve most inconsistency issues for most CSers). The other half is the lever operation which is famous for being forgiving as you noted- there is a reason why the levers have a cult following and are a hidden gem. Not trying to encourage upgraditis or to hint anything... but when you are ready to jump to a commercial spring lever, even that last bit of the temperature issue will be alleviated, just cups after cups of godshot.
    p/s: Oh, for starter, you can look into getting some liquid crystal temperature strips for monitoring the group temperature. Speaking of which, I have two extra 60-90C strips sitting unused. I can pop into the mail and up your way if you can't find a local source (I sourced mine in a pack of 10 from some local instrument company a while ago and have no use of them now).
    Dimal and OCD like this.
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    Thanks for your reply samuellaw178.
    For me even thinking about upgrading is tantamount to 'suicide by wife.' I swear she can read my mind. Or maybe she just smells fear.
    Although temperature strips are on my 'to buy' list I wouldn't want to put you out by taking advantage of your generosity. However, pointing me in the right direction would be much appreciated.
    Dimal likes this.
    Feb 2011
    371
    We are all in the same boat aren't we...especially after a recent significant expenditure and all the promises about that being our last upgrade.....for a month
    Sure thing. Will pm the detail as it's non-sponsor (couldn't find any coffee supplier that sells them either).
    OCD likes this.
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    When I fitted Cremina with a 60C to 90C temperature strip, it was akin to turning a light on in a darkened room. All of a sudden I could see what my various attempts at temperature surfing were/or weren't accomplishing.
    My initial, very rudimentary, technique is as follows:
    * Turn Cremina on with the portafilter locked in.
    * Bring her up to temperature (approximately 15 minutes).
    * Relieve the false pressure (via the steam wand).
    * Lift the lever to the top, purge some water, then return it to its starting position.
    * Raise the lever to the 9 o'clock (horizontal) position, then lower it back down - 3 times. At this point the temperature strip reads 75C which is my sweet spot.
    * After pulling the shot the reading climbs to 90C and needs cooling back down to 75C for any subsequent shots. Easy as...
    Ps how you cool the portafilter and the temperature you choose will depend on your ingenuity and preferences.
    Ps 2 to get the described readings, I fitted the strip as close to the flare as practicable, with the right side of the strip on the front centre line. Being right handed this setup works well for me, visibility wise, and my 75C sweet spot is in the centre of the strip. See pic.
    Dimal, flynnaus, Paolo and 2 others like this.
    May 2016
    Abbotsbury
    122
    Hey mate... would you mind awfully pm’ing me re where to purchase the strips as I would very much like to get some for my leva.
    Can find plenty on US sites but not sure if you got them locally in AU.
    Much appreciated and by the way the Cremona looks beautiful.
    Alastair
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    I don't believe I'm stepping on any CS sponsor's toes by divulging that I bought the strips from RS Components Pty Ltd. You can buy as a guest so don't have the hassle of passwords etc. They are NSW based and proved honest & reliable.
    Ps Cheaper in US but freight about $70 - go figure.
    Dimal and Hoggers like this.
    May 2016
    Abbotsbury
    122
    Hi OCD...
    That is where I ended getting them from as well. They are just down the road from me so picking up a pack of 10 next week. If anyone needs any just ping me and I can send a few out as I won’t need all 10.
    Cheers.
    OCD likes this.
    Dec 2011
    PRL
    2,767
    ???? Standard (US Post) postage from the guys who sell the Lido was $2 US when I ordered some replacement strips for my Achille. Struggled to find any local sources...obviously didn't look hard enough.
    OCD likes this.
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    Quote Originally Posted by Barry O'Speedwagon View Post
    With the exception of your example, I found the US prices (landed in Aus) to be invariably exorbitant. A couple of examples being:
    $6 each - $30 freight.
    $12 for 10 - $70 freight.
    Leading me to giving up on US sites in disgust. Besides, I'd rather support a local business.
    A CSer directed me to the 1st Aus site I tried, but it didn't pan out (my browser kept telling me the site was unsafe - something to do with security certificates, as I remember). Ymmv. To cut an overly long story short, I finally stumbled onto RS Components Pty Ltd.
    I hope I've saved interested CSers some wasted hours - and dollars. Caveat emptor.
    Ps there are only 613,200 hours in a 70 year lifespan and most of them are spent working or sleeping, leaving precious little time for making and enjoying fine coffee.
    Ps 2 it is said that a wise man learns from his mistakes. I prefer to learn from other people's mistakes.
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    Quote Originally Posted by Hoggers View Post
    Hi OCD...
    Cheers.
    Hi Hoggers,
    Don't be too keen to give your temperature strips away. During my research into them (before purchase) I discovered that they go stale after a while and need replacing. Also, if you exceed their rated capacity (whatever that may be) they'll die on you.
    Now, this might be the hoarder within rearing its ugly head, but every time I get rid of anything (with the possible exception of my ex missus), I usually find that I have a hitherto unforeseen use for it. If only the rest of my rainy day clutter took up as little room.
    Ps I do applaud your generous spirit nevertheless.
    Hoggers and Jackster like this.
    Feb 2011
    371
    Just to share a bit more detail about the 'staling'. I've used one for about a year plus. The strip just got slightly fader over time but was still usable. I didn't notice that until I'd placed two strips side-by-side. If you have 3 or so that'd last you for 5 years easy. Not sure if these have a shelf life (probably do), so it might be time to buy new fresh strips anyway (assuming that you manage to resist upgraditis until then).
    OCD and Hoggers like this.
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    I've had Cremina for about 6 months now. Recently I've noticed some uneven brown deposits in the sight glass. When I shone a pen light into the boiler I saw the probable cause. A golden/brown coating which was beginning to flake off. Time for a clean of some sort.
    Olympia vaguely suggested a descale every 6 to 12 months with "a commercially available liquid decalcifying solution" but definitely not with citric acid or vinegar. I firstly did a high pressure water flush which just exacerbated the flaking. Thinking the coating might be coffee residue I then, unsuccessfully, tried coffee detergent.
    It seems there are two ways to remove scale/calcium, either physically (no thanks) or chemically. Apparently the only chemical that can dissolve scale is acid, which would be great - if that was all it dissolved. The trick is to find an acid that is gentle on Cremina whilst being tough on scale. There are many to choose from - all expensive. After some research I've ordered some Aussie made 'Cafetto LOD' which is reportedly environmentally friendly and gentle - fingers crossed.
    I will let CS know if Cremina survives this chemical assault.
    Ps if any CS have a compelling reason why I should desist, I would be most grateful to hear about it.
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    My bad.
    What Olympia Express actually said was: "Please do not use acetic acid nor white vinegar!"
    Cafetto LOD contains citric acid and tartaric acid so, hopefully, should be ok to use on Cremina.
  23. #23
    Feb 2019
    1
    Some while back we started using proper sized Teflon washers in place of 2 of the 3 copper crush washers on the Cremina. One of these spots is under the pressure safety valve. If you use Teflon in that position you can just remove the PSV and clean the tube with the proper tube brush without bothering with a new copper washer again and again. Teflon is reusable. Sometimes mechanical cleaning is better than chemical.
  24. #24
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    The descaler (Cafetto LOD) arrived and was employed in accordance (mostly) with Olympia Express' instructions. I opted for baby steps to minimise any possible damage to Cremina. Instead of the 1 to 5 ratio recommended I went with 1 to 12. It removed some scale (mainly from the bottom of the boiler???) and, from what I can see, without damage. I'll try full strength next time.
    The instructions are as follows:
    01 Open the boiler top of your Cremina. Empty the boiler water. Pour in the liquid descaling agent into the boiler and fill with water.
    02 Open the steam tab of your Cremina and close the boiler top. Leave the cold liquid to work for 2 to 3 hours.
    03 Place a container under the steam tab and another container under the brew group of your Cremina.
    04 Empty out the descaling liquid and rinse the boiler 2 to 3 times with fresh water. Fill the Cremina with fresh water, only now heat up the machine.
    05 Let the steam come through the steam valve and perform 2 to 3 extractions without portafilter with your Cremina.
    Ps consumer reports of flaking/dissolving metal have prompted Olympia Express to warn that "These instructions replace all previous descaling instructions in the owner's book and online".
    Ps 2 I modified instruction #1 to comply with the golden rule: "Never add water to acid. Always add acid to water".
    Ps 3 I ignored instruction #03 and instead just upended Cremina, drained the descaler and then flushed the boiler with a garden hose.
    SanderP likes this.
  25. #25
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    It's been a week since my first wimpy, and consequently unsuccessful, attempt at descaling Cremina. No holding back this time.
    Cremina needs 1,300ml of water to reach the 'max' mark and 2,060ml to reach capacity. I figured 2,000ml would be workable amount (it does froth up a bit, increasing the volume).
    Dividing 2,000 by 6 gave me 333 so I went with 333ml Cafetto LOD to 1666ml water, giving me one part descaler to 5 part water - as recommended by Cafetto.
    * Poured mix into Cremina.
    * Employed gravity to flush some of this mix through Cremina by lifting the lever and opening the steam tap.
    * Lowered the lever, closed the steam tap then soaked for 2 hours.
    Result: when I shined a light into the boiler I saw nothing but clean metal. Ditto the sight glass, and no obvious damage - so far.��
    Ps if anything untoward crops up I'll report back.
    Dimal, SanderP and 338 like this.
  26. #26
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    Because the lever pivot points on Cremina are under extreme pressure they need regular oiling or, even better, regular greasing. Unfortunately to be effective greasing requires disassembly which, in my case, means it would be put off for another day. The oil pictured is rated for extreme pressure, has a mess-free needle applicator and is supposed to be 'food safe'.
    Ps works for me.
    Ps 2 let you know if it worked (or didn't) for Cremina - in a few years time.
  27. #27
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    12 Months On
    One year on and, other than needing (and getting) a descale at about 6 months, Cremina has been rock solid.
    For my peace of mind I disassembled, cleaned and lubricated the rear lever pivot pin and its track. It was still pristine - see pictures.
    I've read that the piston seals need replacing periodically and have bought a seal & gasket kit to suit. However, that won't happen until the seals start to leak. No sign of that yet.
    Any buyers remorse? Yes, I should have bought Cremina sooner and saved a couple of grand.
    Ps at the rate Cremina is wearing out, the grandkids will likely inherit her - to sell at a garage sale for $20 - C'est la vie.
  28. #28
    Dec 2011
    PRL
    2,767
    Hi OCD,
    Out of interest, what pressure does your gauge settle at? I know that the Cremina advertising blurb suggests that they sit between 0.7-0.8 bars, but my recent purchase certainly sits higher than that. It seems that their factory setting is more at 1.0 bar level. I'm very much enjoying it thanks to threads like yours and a few on HB. But I'm thinking of opening her up and dropping the pressure a little. Certainly no lack of steam power....I've completely lost my mojo in that respect.
  29. #29
    May 2008
    4,209
    My '87 Cremina doesn't have a built in gauge but I have a manometer I can attach to the steam wand. The boiler pressure does sit between 0.7 and .8 bars. I adjusted it to .75 bars (up from .7) and provides great shots with sufficient steam to texture enough milk for 2 cups.
    Barry O'Speedwagon likes this.
  30. #30
    Dec 2011
    PRL
    2,767
    Cheers. That's sort of what I suspected. Looks easy enough to open up with a 30mm socket (when I find it ) At the moment I'm dropping the pressure by releasing some steam before pulling the shot.
  31. #31
    Jul 2017
    457
    Hi OCD,
    Out of interest, what pressure does your gauge settle at? I know that the Cremina advertising blurb suggests that they sit between 0.7-0.8 bars...
    I have seen a few and would confirm that.
  32. #32
    May 2008
    4,209
    I adjusted the pressure on mine via the pstat . Accessing it required removal of the cover. Wait until the Cremina is not up to pressure so you can safely remove the boiler cap then unscrew the ring nut to remove the plate and then the cover. Then make sure there is sufficient water in the boiler, turn it on and wait for the Cremina to come up to pressure. If your Cremina doesn't have an antivac valve, make sure you bleed off the false pressure via the steam wand.
    See this thread to adjust the pstat
    https://www.home-barista.com/levers/...nt-t44781.html
  33. #33
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    ...Out of interest, what pressure does your gauge settle at?...
    Probably higher than it needs to be, but doing the job.
  34. #34
    Dec 2011
    PRL
    2,767
    Thanks very much OCD. Yeh that's exactly where mine tops out. Going to have a play with the pstat on the weekend. From my experiences using the Espresso Flair, I reckon my palate appreciates a slightly lower brew temp.
  35. #35
    May 2008
    4,209
    Probably worthwhile sticking with the default pressure setting until you are used to the machine.
    There is an old thread on HB about pressure adjustment on the Cremina
    https://www.home-barista.com/levers/...ing-t3381.html. One post suggests adjusting pressure via steam release which is sensible.
    You must tell us a bit more about your latest addition to your coffee brewing arsenal Barry. Brand new or did you snap up that white one that was advertised on CS recently (I would have) ? Congrats on either.
  36. #36
    Dec 2011
    PRL
    2,767
    Ta. I bought the one that was recently advertised here. Originally purchased in 2017 from Coffee Parts, little used. Basically in perfect nick as far as I can tell. Was originally using my OE Lido ET with it, but recently received my Niche and so have whipped it into service. I have been experimenting with using the steam valve to drop the pressure as per the HB thread(s). Very happy with the results thus far. I'm not sure that I've nailed the dosing and distribution yet. I'm presently dosing the portafilter using the plastic funnel from the Espresso Flair, which 'almost' fits. Have a 49mm OE funnel on order.
    Dimal likes this.
  37. #37
    May 2008
    4,209
    For what it's worth, I hooked up the manometer to my Cremina this morning. The pressure ranged from .7 to .9 bar on an Armaflex(?) insulated boiler.
    Seems to have crept up a bit since my initial adjustment two years ago unless I didn't adjust it properly in the first place. More than happy with the output though.
  38. #38
    May 2008
    4,209
    Bargain! I had to exert considerable self control not to jump on that one.
    My dosing funnel is the bottom of a Dairy Farmers 150g yoghurt container, cardboard cover removed of course. Works well.
    I grind 14.0 g into the basket and tamp with a Pullman 49mm tamper. The previous owner ground down the old portafilter to a naked. I also have two 49mm baskets, one being the original, the other a La Pavoni.
    My shot pouring method is to raise the lever to just above horizontal, lock in the pf then raise the lever to the top for a 10 second pre-infusion before pulling the lever down. firmly at first then tailing off the pressure as the shot progresses. Ca plane pour moi.
    A Cremina and a Niche?! Being a Canberra lad, you didn't manage to get on some Federal grants list courtesy of Sen Bridg McKenzie did you?
    The NZ is on my list of future upgrades but have resisted the temptation so far. Perhaps wait for v2.
    Dimal likes this.
  39. #39
    Dec 2011
    PRL
    2,767
    Yeh, I've largely been using your shot pouring method, interspersed with some attempts at the double pull a la the guy on HB. Both approaches have worked well. Certainly at least at the Plastic Bertrand-level, but maybe not quite James Brownesque. A naked portafilter will be useful.
    Didn't manage to land any grants unfortunately. The decision to buy the Niche was encouraged by the fact that I've got to fix my M4D (probably just a capacitor). and the ease of experimenting with different grind settings got the better of me.
    Dimal and flynnaus like this.
  40. #40
    Sep 2009
    328
    Didn't manage to land any grants unfortunately....... I've got to fix my M4D (probably just a capacitor). .
    No need to Stress Barry O'.....There'll be another round coming along soon !
    PS the start run capacitor replacement are pretty straight forward ...plenty of pics, a diagram or two. CP likely has the part. If the original is stuffed its likely to have a melt point on the case.
    But then you'll already be one step past this.....
    Good thread read fellas !
    Dimal likes this.
  41. #41
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    Probably worthwhile sticking with the default pressure setting until you are used to the machine...
    Ditto. Snap decisions (or promises) during a honeymoon phase have rarely ended well for me.
    According to this chart, at 1 BAR, I should be burning the crap out of my coffee. I'm guessing the water must be shedding a fair bit of heat on its way to the puck.
    Extensive taste testing at differing pressures would, no doubt, be instructive. Anyone up for it?
    Cremina is only 18 Months old. Maybe different pressure settings work best for different models.
  42. #42
    Dec 2011
    PRL
    2,767
    Quote Originally Posted by EspressoAdventurer View Post
    Yeh, I got as far as flipping the grinder over and looking for my multimeter, and when the screws in the base plate wouldn't behave themselves I put it off for another day
    UPDATE: I've opened the M4 up, removed the old capacitor (not visibly fried) and ordered a new one. Will have to get a cable tie to attach the new capacitor to the top of the chassis
    But back to the Cremina tomorrow.....
  43. #43
    May 2008
    4,209
    I should correct this. I believe your Cremina would not have the old mechanical pstat as portrayed in the video. Rather, I think they use a Sirai pstat or similar and adjustment would likely be by means of a screw on top of the pstat.
  44. #44
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    .8 BAR vs 1 BAR Musing.
    The temperature difference between .8 BAR @ 117.14C and 1 BAR @ 120.42C is only 3.28C.
    Given that the ideal extraction temperature (at the puck) is somewhere around 92C, I wonder how critical a boiler temperature variation of 3.28C can be in practice.
    Surfing the group head temperature, so that the water arrives at the puck at the desired 92C (give or take) should mitigate any temperature variation in the boiler.
    On the other hand: higher boiler pressure = more steam.
    Ps boiler pressure has no bearing on extraction pressure - only on pre-infusion pressure.
    Ps2 there will, of course, be factors I haven't taken into account. Your thoughts? Criticisms?
  45. #45
    May 2008
    4,209
    This post deserves a response andcould be worthy of its own thread. I haven't got into boiler temperature changes other than the trade off betwen shot quality vs steam volume. I would guess there would be some variation in shot quality over the 3 c range you mention.
    Other factors would affect shot quality afforded by extraction pressure would be length of preinfusion, lever pulling technique, grind quality, filter basket quality,
    The question worth considering, especially with a machine of the quality of the Cremina is whether there is a need to change the boiler pressure at all (from default) given the other factors available. I guess the answer is why not if it provides significant improvement to your shots but what you could achieve the same improvement via other means.
  46. #46
    Dec 2011
    PRL
    2,767
    I guess part of the answer is that Cremina's universal advertising blurb for their own product, states the following (this is from Coffee Parts, but is extracted from Olympia's press pack elsewhere): "The default pressure is adjusted to between 0.7 and 0.8 bars and the brewing temperature to 92.2 deg C. The Cremina leaves it to the skill of the barista to find the required nine bar pressure onto the portafilter by lowering the lever at just the right time."
    https://www.coffeeparts.com.au/olympia-cremina-black
    I still haven't adjusted mine yet, but will likely give it a go soon.
    flynnaus likes this.
  47. #47
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    ..."The default pressure is adjusted to between 0.7 and 0.8 bars and the brewing temperature to 92.2 deg C. The Cremina leaves it to the skill of the barista to find the required nine bar pressure onto the portafilter by lowering the lever at just the right time...
    I knew my Cremina was a precision instrument but to read that it's set at 92.2C brewing temperature - unbelievable. And here I was, wasting my time with all that unnecessary temperature surfing.
    Could someone elaborate as to the right time to lower the lever so as to achieve the stated 9 BAR extraction pressure? I don't think I'm getting anywhere near 9 BAR. My timing is obviously way off.
    Also, my Cremina was never set to between .7 and .8 BAR.
    I'm starting to think I've been lumbered with a counterfeit Cremina, albeit a damned good copy. Most likely South Korean.
    Ps and the clincher. It's not even black. More of a dark metal flake grey.
  48. #48
    Dec 2011
    PRL
    2,767
    Seem to be quite a few people on HB who received theirs with the pstat hovering in the range of your machine and mine. And quite a few who received their machine with the pstat in the 0.7-0.8 range. I guess it might depend on what the retailer does in the bench test (assuming such an event occurs).
    OCD likes this.
  49. #49
    OCD
    OCD is online now
    Feb 2013
    Ballarat
    361
    ...I guess it might depend on what the retailer does in the bench test (assuming such an event occurs).
    With the possible exception of the foreign power plug thingy they shipped the machine with, I can't imagine Olympia Express getting it so wrong that the dealers couldn't, in good conscience, allow the machines out of their showrooms without first pulling them apart to put things right.
    Ps if you decide to go ahead and lower your pressurestat settings, let us know how it works out for you.
  50. #50
    Dec 2011
    PRL
    2,767
    Will definitely let you know when I do have a go. Looks easy enough to open up. Just switched bags of beans so I'll stick with my current set up til at least the weekend.
