Results 1 to 5 of 5
Thread: Flushing an UNO E
    Aug 2007
    7
    Flushing an UNO E
    Hi.
    Not sure if this is the right price range for an UNO E but have just acquired one after a thermoblock. I ran that on filtered de-ionised rain water and never had to flush with cleaner. I am running the UNO on same water and not sure if it needs blind flushing, which part of the pipework it actually flushes and how often it should be done. Any suggestions appreciated.
    Also any suggestions on procedure to obtain best results from idle (bleed the cold then hot water supplied to group, etc.)
    Thanks.
    Senior Member Dennis's Avatar
    Feb 2007
    4,512
    Re: Flushing an UNO E
    Hi Steve and welcome
    Maybe you could contact one of the people who posted in the following thread (pm or email) and they may be able to help, if its a similar machine?
    http://coffeesnobs.com.au/YaBB.pl?num=1185746591/3
    Feb 2005
    2,971
    Welcome to the forum Steveedmonds.
    Not familiar with your machine, unfortunately. "Uno" tends to be a fairly generic term for models, meaning "one" as in one-group, rather than a brand.
    If it has a three-way valve, it should probably be backflushed with a blind filter. With its own water. And with a chemical cleaner every fortnight or so.
    Perhaps you could post a picture.
    Aug 2007
    7
    Sorry robusto, left off the obvious, the brand. Carimali Uno E.
    Feb 2007
    4,512
    Steve, the original post I made also refers to Carimali machines.
  1. Back flushing.
    By Yelta in forum General Coffee Related...
    Last Post: 4th December 2009, 12:20 AM
  2. Flushing Blend
    By Bullitt in forum Blending Room
    Last Post: 1st November 2006, 11:19 AM
  3. Flushing silvia
    By Clonetrooper in forum Brewing Equipment (non-machine specific)
    Last Post: 25th April 2006, 09:34 PM
  4. Back Flushing
    By admin in forum Brewing Equipment (non-machine specific)
    Last Post: 24th December 2004, 08:16 PM
