Results 1 to 3 of 3
Thread: Dis-assembling Carimali Uno E
    Aug 2007
    7
    I am starting on a tuneup of my recently purchased Uno. I have 2 manuals and none explain how to get into the thing.
    I found a knurled nob front high by the steamer/water. A pin and slide low down centre on the frame. I can flex the side in and out but not dislodge it from the back.
    I dont want to break the thing, can anyone explain how,if the sides come off one at a time. How do they disconnect at the back.
    Thanks. steve
    Senior Member Dennis's Avatar
    Feb 2007
    4,513
    Re: Dis-assembling Carimali Uno E
    Hi Steve. If youre able to post some pics Im sure someone here will be able to help.
    May 2006
    37
    I cant say for sure your model will be the same as mine, as the design has changed over the years.
    But for my Uno, to remove the panels you:
    Start at the top and take out the plastic slats that your cups rest on, revealing a metal plate which may or may not be screwed in place. Remove this, and unscrew the cover of the top of the rear panel.
    Under this cover there are two holsters for prongs mounted to the side panels, these can be slid out, freeing the prongs.
    Now to remove both side panels you have to loosen two large circular nuts on both sides of the front frame (about the height of the group) which fasten another two threaded prongs into the frame.
    At the bottom of each panel there is a very large prong that fits into the frame, which can be locked into place with a sliding lock, obviously you must unlock each side before pulling off each panel.
    I hope this at least gives you an idea of where to start. Remember that the most important thing is to TAKE YOUR TIME. Look closely and carefully study the structure of the machine.. parts arent always readily available so you really do not want to mistakenly damage anything!
  1. Carimali F11
    By Rochellecraig in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 7th September 2007, 08:02 PM
  2. [m]: Carimali F11
    By Dimal in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 8th August 2007, 08:39 PM
  3. Carimali
    By lennier in forum Brewing Equipment (non-machine specific)
    Last Post: 1st November 2005, 03:10 PM
