Results 1 to 12 of 12
Like Tree10Likes
  • 5 Post By Plane24
  • 1 Post By Plane24
  • 2 Post By Plane24
  • 1 Post By Plane24
  • 1 Post By Cats
Thread: Profitec Pro 700 front external drain port
    Nov 2019
    6
    Just bought a profitec pro 700 and still getting used to it. Big upgrade over the breville!
    Is it normal for it to periodially drip every now and then (just like a single drop).. maybe 10mins or so if the machine is sitting idle?
    Senior Member WhatEverBeansNecessary's Avatar
    Apr 2017
    Adelaide
    494
    No, I don't think so.
    Have a chat with who you bought it from.
    Oct 2017
    36
    Yes it is quite normal - I have a 700 and the external drain produces a drop every so often. It is the collected steam and boiler hot water etc from inside the machine. I read somewhere that many Italian espresso machines allow this to remain inside the machine but the German engineers who designed the Profitec captured it all and drained it safely into the drip tray to avoid condensation inside the machine.
    It is a feature - not a bug!
    Enjoy your Profitec 700 - they are superb machines.
    Dimal, level3ninja, hawk87 and 2 others like this.
    Nov 2019
    6
    Plane24 thanks!! What im concerned about is rusting the powder coated steel section that is exposed between the lip on the front panel and the drip tray.
    Do you find condensation/wayward drips from either the 3way valve or the vacume valve drip manage to find their way there?
    It usually looks reasonably dry but you can tell moisture condenses there either from the steam at startup or because water is lipping around the bottom bent edge of the front panel.
    https://ibb.co/gFqN12C
    My drip tray is fully in and touching the chassis so there is no gap but moisture still manages to get in to some extent leaving a watermark.
    Given this feels like its normal.. as there seems to be an obvious opening and no way to stop steam condensing here, im wondering why they didnt make this stainless steel.
    Do you have this? Will it rust over time? How long have you had yours?
    To be clear, its not soaking wet, just an amount of moisture leaving a feint watermark and the drips that sit on the top of the water tray after initial heat up dont help
    Oct 2017
    36
    Cats
    I have had my Profitec 700 for two years. There is no sign of any watermarking on mine. The drips of condensation fall straight through the square cutout in the drip tray cover (which is obviously put there for that purpose). The drips do not hit the stainless steel lip at all. Even if moisture were to get on to the powder coated steel section below and behind the lip I would expect it to evaporate quickly given the machine is always warm. When I touched the powder coated section you are concerned about it was gently warm and bone dry.
    I have taken a video which I will try to upload - it shows a couple of drips forming and then falling as I described above.
    If yours does something different then you may need to contact your dealer.
    Paul
    Dimal likes this.
    Oct 2017
    36
    Cats
    Looking at your photo I wonder whether the mark you refer to might well have been on the label before it went on the machine?
    Here is a link to the short video I took of water drops:
    https://share.icloud.com/photos/0iDu...Frenchs_Forest
    Paul
    level3ninja and hawk87 like this.
    Nov 2019
    6
    Hi Paul, the watermark wasnt there orignally, as i can spray and wipe it off, and it comes back depending on what occurs, condensation or splashes etc.
    The moisture is coming at startup i think?
    The steam generated when the steam boiler heats up causes condensation in the whole region including the chassis.
    As you said, it is warm to touch so it probably dries.
    If you have any moisture/watermarks on the chassis it is far easier to see under a torch or phone flash.
    At this point i think mine is operating just like everyone else's. If there is any moisture people simply arent looking for it, but im pretty sure it's going to be there.
    I found putting paper towel on startup will prevent the initial contensation.
    The gap between the chassis and the drip tray allows water to run down it before it dries
    Oct 2017
    36
    Hi Cats
    I have done some tests and I think I may have a possible explanation. First thing to note is that my wife and I only drink long black coffees. So we rarely use the steam wand. This made me wonder whether that might be an issue.
    So this morning I waited while the 700 came up to working temperature and then very carefully checked the black panel using a torch and tissue paper. It was absolutely bone dry. So then I replaced the drip tray and turned on the steam wand with the steam shooting into the drip tray. NaturalLy I got condensation of the cooler parts of the stainless steel face plate of the 700 (around the dial etc) and lots in the drip tray area itself including the stainless steel lip at the bottom of the face plate where it hangs over the drip tray. But when I removed the drip tray there was condensation of the black powder-coated panel behind the drip tray. Which is what I believe you have seen.
    I just checked now and in the time it has taken to type this the moisture on the black panel has evaporated.
    So I wonder whether the moisture you are seeing is coming from the steam wand?
    Paul
    Dimal likes this.
    Nov 2019
    6
    Hi Paul,
    Its definitly not the steam wand, this is only during startup.
    As the steam boiler hits maybe 96-100C steam and condensation come out of the vacuum discharge valve until you hear it abbruptly shutoff at 100C (as designed). The condensation heats a radius of around 5cm of the surface around the discharge nozzel. If you look under the lip at this point in the process there are little beads of moisture under the lip on the chassis.
    I cannot think that anyone elses is behaving differently here, the steam is pretty much going to go everywhere intil the valve shuts off, which doesnt happen until 100C.
    Does yours have steam coming out at startup?
    Of course, if you have the steam boiler switched off this wont happen, as its strictly associated with the steam boiler in the last few degrees of heatup before the vaccume valve seals at 100C.
    Ive found if you block the gap under the lip, the steam fogs up as far as the pressure gauges.
    hawk87 likes this.
    Nov 2019
    6
    Hi Paul, this references what i believe the machine is doing:
    https://coffeetechniciansguild.org/b...vacuum-breaker
    "When heating, this allows hot expanding air to escape until it is replaced by true steam pressure."
    On startup hot hair will mimic steam, giving only a short blast of hot air after which the unit will heat normally.
    Id be very interested if you could have a look at that point in the startup if you get condensation/hot air/steam for a few seconds and then you will hear the breaker engage (a quiet little 'thuppp' sound then no more steam)
    Edit: this post describes it too
    https://coffeeforums.co.uk/topic/394...acuum-breaker/
    Oct 2017
    36
    Hi Cats
    Like you I do get some steam and a few drops of water during warmup which stop with a click once the temperature gets to 100C and the valve closes. There is naturally some condensation from the steam around the outlet which evaporates fairly quickly. I have never removed the drip tray at that point to check but will try to do so tomorrow and let you know what I find. Based on my test using the steam wand I would expect there will be some condensation - the steam is under pressure of course.
    On my machine the black area looks to be powder coated (not simply painted) and any condensation evaporates quickly. The steam is by definition distilled water and so is any condensation. Profitec and ECM have a well deserved reputation for German engineering, design and high quality manufacture so I am confident this has been thoroughly considered and tested over many years.
    I would encourage you to relax and stop worrying about it. Just enjoy you new machine and the great coffee itís producing.
    Regards
    Paul
    Nov 2019
    6
    I was wondering if it was powdercoated but i dont know what to look for in the differences between paint and powdercoating (im aware of the differences in process but not what to look for in the end product)
    The powdercoated chassis on the Syncronika is distinct and also called out in the marketing material
    I do agree with you though, im probably overthinking but you know how it is with things you invest in, you want to do everything you can to ensure they last as long as youd like them to.
    You dont need to remove the drip tray (necessarily) after the steam at startup you will see some condensatipn droplets if you shine a light in between the lip and the drip tray (under the discharge vent)
    I am fairly certain at this point everyone's machine is behaving the same, and i wish they'd made it stainless steel but i guess if yours is also condensing there and you have no wear in the powdercoat then its a non issue
