Results 1 to 5 of 5
Like Tree1Likes
  • 1 Post By Beanz.
Thread: Profitec Pro cup tray
    May 2008
    4,275
    Most of the Profitec range feature a removable cup tray for easy access to the water tank. I'm finding the protective rubber pads under the tray tend to stick a bit to the top of the machine and leave a mark which is only visible when the tray is removed and fairly easily removed with Cafetto.
    I'm finding the stickiness a bit of a nuisance. Anyone else experience this and if so, what have you done about it? I have 7 cups sitting on the tray most times and perhaps the weight of these is causing or contributing to the problem??
    Dec 2009
    SYD
    611
    Is it an option to plumb?
    May 2008
    4,275
    Thanks for the suggestion. I have a Pro 600 which is not plumbable but even if it was, it wouldn't be a justifiable expense to solve this problem.
    Senior Member Beanz.'s Avatar
    Apr 2009
    253
    I have a Profitec but have not had the same issue. A very thin coating of Dow 111 and then wipe off any excess should overcome the problem
    flynnaus likes this.
    May 2008
    4,275
    Cheers. That sounds workable. I don't have Molykote but I do have some Inox that should do the job.
