Results 1 to 4 of 4
Like Tree2Likes
  • 1 Post By LeroyC
  • 1 Post By LeroyC
Thread: Boema Rebuild and Modification
    Jan 2014
    2
    I have pulled apart and cleaned thoroughly my single group Boema and wish to get it operational prior to making some modifications and upgrades.
    I didn't take sufficient photographs of the pipe layout, is anyone able to check the attached images to ensure I have laid it all out correctly.
    Jan 2014
    2
    Can anyone confirm that this is the correct order for assembly of the water charge unit?
    Also are these brew tanks over pressure valves reliable or should I swap it for a newer/better part?
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,401
    Anti-vac valves should be replaced each service. Safety valves can last a bit longer, but be prepared to replace them as well. Iíll see if I can find some photos of my Boema and upload some photos later today of the piecework.
    3GGG likes this.
    Sep 2013
    2,401
    This is the only photo I could find sorry. Hope itís slightly helpful-
    3GGG likes this.
