Results 1 to 4 of 4
Thread: Caramali uno e  pump not working
    Oct 2007
    1
    after a year away we set the machine up and started the baby up to make a couple of cups to celebrate our return home but after reaching the desired pressure, and pushing the button for a double shot ,it just oozzzzed out and Im not sure I heard the pump. we live out in the sticks so no ability to just wip down to the local espresso bar for a quick shot, its serious. any ideas what the problem is? and how to fix it, any help much appreciated, if we survive
    Feb 2007
    47
    Re: Caramali uno e *pump not working
    Not familiar with the model however it would help if you can advise if the machine has a vibrating solenoid OR impeller water pump.
    Either way the pump is most probably seized due to long inactivity.
    That does not mean the pump is not recoverable, but method will vary depending on the type of pump noted above.
    Of course, it may not be recoverable but you will not know until you try.
    Senior Member phil_jeffery's Avatar
    Feb 2006
    109
    Re: Caramali uno e  pump not working
    Hi,
    As Curmudgeon mentioned, the pump is probably frozen from inactivity.
    The first and easiest thing to try is to remove the pump from the motor and lines. If its a rotary pump, the shaft is most likely like that in the below pic. Use a shifter on the shaft and try to rotate it until its free enough to turn by hand. If you can get to that point and you intend to use the machine regularly again, it should be O.K. If it doesnt free up, or it keeps seizing, the next step would be to attempt to descale with an organic acid such as citric or tartaric acid.
    But try to free it up just by rotating first, its eay enough to try.....has it seen a lot of use?
    Regards,
    Phil
    May 2006
    37
    I mostly agree with what phil has suggested, however Id remove the pump and try turn the shaft using only a small amount of force (ie. you may only want to use your hand) and if you find its too tough to turn without excessive force, you could then soak it in some citric acid or similar acidic solution to dissolve any calcium build up that may have caused the seizure.
    Hopefully after doing this you should find it turns a lot more easily.
  1. Breville 800ES: pump stops working after a few secs of providing coffee
    By jslikker in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 29th June 2016, 09:17 AM
  2. Giotto premium vibratory pump not working
    By Listener in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 8th September 2011, 08:32 AM
  3. **GONE**Free Cafe Crema EM4800C - pump not working
    By ashleykvincent in forum Paid Forward - Taken
    Last Post: 15th June 2011, 06:33 AM
  4. !!SOLD!!: Caramali (Oscar)
    By AREXTwo in forum SOLD
    Last Post: 30th December 2010, 11:07 AM
