Results 1 to 3 of 3
Thread: grounds stay in group head on Boema
    604
    Hi All
    A quick question- on my 1 group Boema I get grounds outside the showerscreen/ dispersion block after I remove the portafilter. By that I mean on the sides of the block (showerhead) and edges of the group seal. I didnt get this on the Bezzera even though it is the same or similar to the Boema. I also dont get it on Botticelli. I usually clean these by doing the p/f wobble (loose in the group head) or with a back flush, but it is every time I use it.
    Im wondering if the dispersion block is a little undersided especially since it has a perforated stainless steel shower screen unlike the usual wire screen one (maybe this is normal for Boema).
    Any thoughts?
    Brett
    Feb 2005
    3,095
    Re: grounds stay in group head on Boema
    Sounds normal, especially if the group seal is halfway up the shower screen.
    604
    Ah, the times when you should trust your own judgement. The shower head was about 5mm undersized. I compared it to an ordinary 58mm style one and the difference was amazing- also there was a difference between the shape- all the ones Ive fiddled with before had chamfered/ bevelled sides that fitted fairly neatly into the filter basket. I had not been able to check before because the thing had a seized screw- amazing what you can do by removing the grouphead and hitting the screw with an impact driver!
    All fixed and happy.
    Brett
  1. FS: 2 group Boema
    By Big_John in forum SOLD
    Last Post: 9th February 2012, 10:21 AM
  2. Boema Group 2 vs San Marino group 2- I need help!!!
    By Bean_On_The_Run in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 22nd May 2009, 08:52 PM
  3. Replies: 0
    Last Post: 22nd May 2009, 07:17 PM
  4. 1 group Boema
    By chelbe in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 14th May 2008, 07:47 PM
