Results 1 to 7 of 7
Thread: Leaking group heads
    Jul 2007
    36
    Leaking group heads
    I recently notice that my group heads seep water when making an esspresso. What do you think may be causing this. I have a Rancilio Epoca 2 group head and it seems to be seeping from both heads. Any hepl would be great.
    Cheers David
    Banned
    Sep 2006
    623
    Re: Leaking group heads
    First guess would be your seals. When were they last replaced? If the water is coming from between the group head and portafilter than thats it, otherwise can you be more specific about where the water is coming from.
    Jul 2007
    36
    Hi Mate, the machine is about 18 months old and usually pours around 4-6 coffees a day. I have not yet changed the sills so this may be the problem as you stated. The reason why I assumed there may be something else wrong is that both group heads leak and there is really only one group heap we ever use. The water that does seep comes from the in between the portafilter and the group head.
    Any suggesstions where i can find new seals for this machine. I am in the northern Suburbs of Melbourne.
    Thanks in advance
    Oct 2007
    38
    coffee parts would be worth a try, failing that try grinders
    14,665
    Hi Jackal,
    You might try Grinders coffee who are the current importers or alternately try Mocopan...
    Good luck!
    Aug 2007
    846
    Jackal, another possible reason for the leakage could be that youre cramming too much grind into the portafilter, thereby preventing the portafilter to lock into place in the group. As an experiment, try less grind, lock the pf firmly in place, & giver her a whirl.
    If it still leaks, totally disregard my theory and get the seals replaced! ;D
    cheers,
    Tony
    ev
    ev is offline
    Jan 2005
    156
    David, 18 months seems pretty long between group seal changes. I change mine every few months before it becomes too hard & brittle. Theyre only a few bucks each so why not.
    Evan.
  1. !!!SOLD!!! - FS: Wega Atlas EVD 2 Group Heads
    By caffaddict in forum SOLD
    Last Post: 9th April 2013, 09:23 PM
  2. Sealing Group Heads to boiler pipes- do I need a sealant?
    By koligi in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 20th February 2011, 04:33 PM
  3. 6910 leaking around group. Advice needed from wise heads.
    By Black_Gold in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 1st January 2011, 04:33 PM
  4. Rancilio MIDI CD, Steam Out of Group Heads + Hot!! Inlet Pipe
    By whitie8000@hotmail in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 15th December 2010, 10:23 PM
  5. [m]: Leaking group heads
    By Dimal in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st February 2008, 04:59 PM
