Results 1 to 2 of 2
Thread: Draining Brasilia Gradisca
    May 2005
    237
    Hi guys,
    I need to move our Brasilia Gradisca 2 group from the shop as we have to close down business. :(
    Can anyone let me know how to drain the boiler so that it is easier to lift and transport?
    Feb 2008
    4
    Re: Draining Brasilia Gradisca
    Hi
    There is a drain plug underneath on the boiler and also a copper pipe laeding into the sight glass, undo pipe on boiler side and also undo drain plug, but rember to remove all of the preasure in the boiler by opening the steam valve before touching anything VERY IMPORTANT unless you will get burnt, It would be good to not use machine for a day before so the water in the boiler is not so hot and therefore easier to drain.
    There will be buildup in the boiler which may block the drain, just stick a piece of wire to move it.
  1. Brasilia Gradisca
    By espressolover in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 5th May 2014, 10:28 AM
  2. Overheating Brasilia Gradisca
    By Tamray in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 25th June 2013, 09:20 AM
  3. Rancilio S24/S27 not draining, what to do?
    By quickling in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 18th July 2011, 10:20 AM
  4. [m by=604D494548240 destboard=BrewExtreme dest=1265759960]: Brasilia Gradisca
    By Dimal in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 10th February 2010, 12:33 PM
