Results 1 to 5 of 5
Thread: Faema Elite Bypass Valve ?
    Feb 2008
    9
    Our first post! Check out our store and machine on YouTube...(website URL)
    Ok...She is a fine girl, but a little tempermental.
    Her boiler bar has a redline at 12, and when she feels like it....She whines and the gauge jumps to 14bar !
    No shot will pull when this occurs. The manual says to adjust the Bypass Valve.
    Is this a common occurrence? We took off the side panel, and found a valve labeled "Bypass"....Our valve has no adjustment.
    Were glad to be a new member here, and look forward to hearing from you!
    DONT USE
    Jan 2008
    432
    Re: Faema Elite Bypass Valve ?
    morning faemalove
    try reloading the link to utube so we can check out the machine.
    graham
    Feb 2008
    9
    Thanks, this was copied from my address bar..
    http://www.youtube.com/user/Faemalove
    Hope it works!
    Feb 2008
    9
    Quoting Myself here
    Quote Originally Posted by faemalove link=1203871847/0#0 date=1203871847
    Our first post! *Check out our store and machine on YouTube...(website URL)
    No shot will pull when this occurs. *The manual says to adjust the Bypass Valve.
    Is this a common occurrence? *We took off the side panel, and found a valve labeled "Bypass"....Our valve has no adjustment.
    :-/ *It turns out that this only happens intermittently, and when it does....Faema our lovely tempermental italian beauty.....Refuses to pull a shot!
    Has anyone ever had to adjust or mess with one of these Bypass Valves? *We have the PDF from Faema, but it doesnt match the ELITE!!
    Regards ;)
    Jul 2007
    16
    Re: Quoting Myself here
    Quote Originally Posted by faemalove link=1203871847/0#3 date=1204237131
    Regards ;)
    Thats the reading for your pump pressure that youre seeing skyrocket to 12 bar.
    How old is the machine?? Perhaps the pump is on its way out?
    The bypass valve, COULD and probably should, be under your drip tray. Or, either way it should be near where your water inlet hose "meets the machine".
    This valve will probably have a slotted front, in which case you should try regulating it anti clock -wise.
    Or, perhaps your pump need to be adjusted at the pump.
  1. Breville BB200 BM - Bypass delayed start
    By Christop in forum Roasters
    Last Post: 14th January 2013, 06:18 PM
  2. Brita C150 filter bypass setting
    By ogip in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 6th November 2012, 09:00 PM
  3. Faema Legend steam valve
    By walshman in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 22nd August 2012, 04:33 AM
  4. faema due-s opv valve leaking
    By stuartm in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 24th October 2011, 07:23 AM
  5. Faema Elite Still Acting Up
    By faemalove in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 12th March 2008, 12:54 AM
