Results 1 to 8 of 8
Thread: Faema Elite Still Acting Up
    Feb 2008
    9
    She sings and whines while pulling shots..Not in a good way.
    Her little gauge hits just over redline, and shots pull slow at best.
    It doesnt happen all the time...we hope theres a couple of you out there that have some ideas! :-?
    DONT USE
    Jan 2008
    432
    Re: Faema Elite Still Acting Up
    hi faemalove
    what is the pump gauge reading when this happens
    sounds like either the pump bypass is sticking and or the cold water relief is letting go. both probs could be related
    graham
    Feb 2008
    9
    Thanks Graham..
    The gauge has only every other number or so, but its redline is 12...
    When it acts up the needle reads over--Id guess 13-14?
    We can only find the factory PDF, and it says to adjust the bypass? How about a Pump Pressure Regulator?
    The service techs out here leave much to be desired!
    Dave and Ann
    DONT USE
    Jan 2008
    432
    hi
    how long has it been playing up for
    does it now happen every time
    how long have you had the machine
    what does the gauge read when it is not playing up
    graham
    Feb 2008
    9
    :PShe acts up on and off every day, maybe skipping a day.
    When she is pulling ok, the Gauge reads below redline(approx 11 ?)
    We could eventually modify her gauge with a more accurate one...
    Shes been taking care of us for almost 2years now.
    Im taking the camera in tomorrow, and Ill capture her tantrum. ;)
    DONT USE
    Jan 2008
    432
    sounds like the Pump bypass is sticking.
    to fix the problem the bypass would need to be pulled apart, cleaned, lubricated and readjusted
    the gauge is mainly used as a guide for fault finding, a lot of manufacturers dont fit then anymore
    the squealing noise is probably the cold water relief valve releasing the excess pressure into the drip tray
    how often is the water filter replaced, and the machine serviced
    graham
    Feb 2008
    9
    Well, the filtration is a nice setup...Ill get a pick of that tomorrow.
    It seems to be the consensus amongst the forums Ive read(bypass sticking/adjustment)
    Ill record the teardown and repair process and add it to the Youtube...It may be helpful to others if this just turns out to be something very simple...
    AND...If we detonate the BOILER, it should make a great "do it yourselfer" blooper!
    Feb 2008
    9
    :)Video of her tantrum :-?
    http://www.youtube.com/watch?v=FiFBbjipDB8
  1. Not Sure If Grinder Is Acting Up
    By dman777 in forum Grinders
    Last Post: 24th March 2012, 05:24 PM
  2. Compak K3 Elite WBC
    By seifried in forum Grinders
    Last Post: 17th September 2010, 03:22 PM
  3. Faema Elite Bypass Valve ?
    By faemalove in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 16th March 2008, 12:49 AM
