Results 1 to 6 of 6
Thread: LaCimbali M28 machines
    JLJ
    JLJ is offline
    Mar 2008
    1
    I am looking at a used Cimbali M28 machine for my restaurant. Are these good machines?
    Jul 2007
    16
    Re: LaCimbali M28 machines
    All commercial coffee machines have the capability to make excellent coffee in a commercial environment.
    The La Cimbalis, like many others, are fantastic coffee machines. *
    Naturally, you will have to ensure the machine is in good condition.
    If it works , first things first, make a coffee out of it. *Get some quality coffee, and check the results.
    If needed, it wont hurt to get a local rep to check it out/calibrate it for you, or a service tech if you experience problems.
    Good news is parts for the Chumblys are readily available (see coffeeparts.com)
    What model is the machine.....Start/select/basic etc
    Dec 2004
    Earth!
    15,757
    The M28s are tanks which with proper maintenance will last a lifetime. They are highly sought after by many leasing companies as they break so infrequently chugging away day after day for decades. My M28 Basic 2-gr is now about 20 years old and still working as good as the day it rolled out of the factory with nothing other than seals ever having been replaced on it. :)
    Java "Still lovin his Cimbali!" phile
    May 2008
    2
    I have a M28 and need to drain the water out! Can someone help me! It is not yet connected to anything electrical, I just need to move it to sell!
    Dec 2004
    Earth!
    15,757
    On some the drain is a plug on the bottom of your fill sight glass assembly. Unscrew the plug from the bottom and open a steam valve.
    On others theres a knob under the sight glass on the front of the machine.
    Java "Still drained!" phile
    May 2008
    2
    Thanks! I will see if I can figure out!
  1. Yet another request for a LaCimbali M28 Manual (sorry)
    By morrisoc in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 10th November 2011, 06:09 PM
  2. LaCimbali not building up pressure
    By Snoop in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 13th August 2010, 10:53 AM
  3. LaCimbali JR D help??
    By blunt in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 6th March 2010, 09:47 AM
  4. FYI - LaCimbali Domus group seal - $0.50 locally
    By coffeegeek in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 16th December 2009, 03:00 PM
