Results 1 to 2 of 2
Thread: FLOJET BW PUMP
    Jul 2007
    31
    FLOJET BW PUMP
    Hi There.
    Would anyone know if FLOJET BW series (bottled water dispenser pumps) are available in Australia??
    Lots are available in the USA but the voltage is 110 V.
    Is there a similar pump here in OZ that would do the job ( on demand pump , running on 230 V up to 40 psi pressure and appr 4-6 liter/ minute pumping.
    spressoman
    Back to top
    Feb 2005
    2,813
    Re: FLOJET BW PUMP
    Try caravan and boating shops. Most pumps meant for pressurised water systems are 12VDC of 24VDC, but Im pretty certain Ive seen 240V AC ones as well.
    Good luck.
  1. FLOJET BW PUMP
    By hankoczi in forum Brewing Equipment (non-machine specific)
    Last Post: 12th May 2008, 09:07 AM
  2. FLOJET BW PUMP
    By hankoczi in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 11th May 2008, 04:09 PM
  3. flojet bw pump
    By hankoczi in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 10th May 2008, 09:24 PM
