Results 1 to 4 of 4
Thread: Carimali pressure relief valve test in NZ
    Jan 2008
    16
    Hi frothers
    My Carimali Unos pressure relief valve is weeping and I need it tested/re-calibrated/replaced. Who in NZ (or could send it to Oz I suppose) can do this.
    DONT USE
    Jan 2008
    432
    Re: Carimali pressure relief valve test in NZ
    check that machine isnt running too hot, if ok and relief valve playing up replace it with a new one
    graham
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    Phone AJ @ Espresso Engineers 09 3612500 if still not sorted.
    CB.
    May 2006
    37
    I had mine replaced from parts I bought from Espresso Engineers last year sometime.. unfortunately they didnt have any with a similar thread diameter, but about 4 fittings later (including one from the original) they managed to assemble something that would work.
    Unfortunately the fittings add extra cost, so dont expect a cheap replacement. And after all that the thing was about twice the length of the original and JUSTTTTT fits. With any luck they might have some different valves in now, but its pretty unlikely.. theyre definitely more of a we will fix your $2500 E61 machine than a sell you parts to fix your obsolete espresso machine sorta outfit.
    A better option might be to measure the thread diameter and try find a compatible valve for another machine on coffeeparts.com.au, or you could try Freshfood Ltd (Robert Timms - Carimali dealer for NZ) and see if you could source one from them, theyre definitely a lot more pleasant to deal with than Espresso Engineers.
  1. PA1051 (Pressure Relief Outlet Fitting) for Gaggia Paros
    By surfziggy in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 26th October 2010, 02:02 PM
  2. Over Pressure Valve OPV
    By seedlings in forum Brewing Equipment (non-machine specific)
    Last Post: 28th October 2008, 12:37 AM
  3. [m]: Over Pressure Valve OPV
    By Dimal in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 21st October 2008, 01:18 PM
  4. Pressure Test
    By SamR in forum Brewing Equipment - Entry level (sub $500)
    Last Post: 19th September 2007, 04:24 PM
