Results 1 to 6 of 6
Thread: Convert i M20 to Rotary machine
    Mar 2008
    3
    I have a M20 with a defective printed circuit board. Unable to replace the board I would like comments on replacing the existing electric units to make it into a rotary pump machine with automatic touch pads. Any help on ideas and particularly suppliers would be much appreciated. Note: This topic posted in CoffeeGeek website.
    DONT USE
    Jan 2008
    432
    Re: Convert i M20 to Rotary machine
    hi
    need more specs on the machine, which m20 specifically
    do you mean the level control printed circuit board
    graham
    Mar 2008
    3
    Correct. The machine is very erratic. It fills up the tank correctly, then overfills it.
    3,498
    That looks like my La Cimbali M20 board (very poor quality photo) ::)
    Replacement boards are still available from La Cimbali agents - but expect to pay many, many hundreds of dollars for one!!! :(
    Someone elses board (costing just as much) could be used.... but the senders (flow meters for volume, water level sensor etc) would almost certainly have to be changed as well.... costing far more than the machine is worth....
    The other, and only low price option, is to turn it into a semi automatic.... i.e. no volumetric flow control. That is what I will be doing (when not if) the computer board in mine fails.
    Mar 2008
    3
    Okay, so to turn it into a semi-automatic machine what would be the parts list? Apologies for the quality of the photo, I was trying to reduce it but havent got the knack of this system yet.
    DONT USE
    Jan 2008
    432
    sounds like the fill relay might be jamming
    bloke in QLD may be able to fix
    cost you postage plus min charge
    email for his details
    graham
  1. Want to convert my San Marino CKX into a dual boiler machine
    By sugilun in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 19th July 2011, 01:58 PM
  2. Minimum pipe size for plumb in rotary pump machine
    By maheel in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 11th November 2010, 09:19 AM
  3. Help Convert Me Please!!!
    By coffeemumee in forum Brewing Equipment (non-machine specific)
    Last Post: 3rd September 2007, 09:00 AM
