Results 1 to 3 of 3
Thread: Boema single group not plumbed in
    Jun 2008
    17
    I have just bought a Boema Single group but I didnt realise that I needed to have it plumbed in. I am at the start of the process of building a new house so I can organise for there but dont want to make a hole in the bench where we are at the moment.
    I think that I have read somewhere that I can run the water in pipe from a bucket or something as it has a pump and put the water out in another bucket or a sink. Is this right? Are there any other options?
    Apr 2008
    Brisbane
    5,113
    Re: Boema single group not plumbed in
    Hi Astro
    It depends if the pump is a self priming pump
    If so then itís possible
    If the pump is not self priming it requires mains pressure
    Others may know more on this but I based my answer on pumps in general
    3,498
    astro,
    Yep, if its got a procon pump it can draw from a container.... and the waste can also be drained into a container.....
    But these are usually done via a hole in the bench..... the same size as if it were plumbed in (or you have messy hoses visible on the outside...)
    Also not having mains feed will affect pre-infusion on these machines..... and there is a much larger volume of waste water (cooling flushes)..... so larger waste container and more frequent emptying.
    Whilst you can "get away without" plumbing them in.... believe me for convenience alone - it is WELL worth it!!
  1. Replies: 8
    Last Post: 24th August 2012, 08:31 PM
  2. Boema single group temp question
    By jam in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 24th May 2010, 12:03 AM
  3. boema single group
    By hankoczi in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 22nd April 2008, 04:35 PM
