Results 1 to 7 of 7
Thread: VBM DS dual boiler PID teaser...
    14,665
    Will be on the bench in the next couple of weeks for testing.
    We will run an open house saturday morning for CSers to come look and pull shots!
    Some factory specs :-
    Group, valves and pump are the same professional grade as the Vibiemme Domobar Super.
    - Steam Boiler 1.4L 100mm x 180mm diameter with 3mm thickness for improved temperature stability.
    - Brew Boiler 1.4L 100mm x 180mm insulated
    - Commercial Sized 12mm Brew Boiler Tubing.
    - Gicar PID and electronics. Custom Boiler Temperature display.
    - Custom made Brew and Heating Elements are maximize efficiency.
    Vibiemme has already sold many units in the European market.
    There will also be a plumbed-in rotary-pump version (electronica).
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    Re: VBM DS dual boiler PID teaser...
    I want one.........
    Sep 2005
    502
    MMMmmmnnn....
    Me too!
    Oct 2006
    91
    Quote Originally Posted by Talk_Coffee link=1217119115/0#0 date=1217119112
    Does this mean that the rotary wont be available as a lever?
    Michael
    14,665
    Quote Originally Posted by g00se link=1217119115/0#3 date=1217202274
    Michael
    Hi Michael,
    I think it will be available via special order. At present, the plumbed version is the Electronica. I believe that there will be a better market for a rotary lever version as well....I guess that time will tell! ;)
    Oct 2006
    91
    Thanks Chris,
    In the absence of Rocket reviving the Veneziano S1, this is at the top of my list.
    14,665
    Quote Originally Posted by g00se link=1217119115/0#5 date=1217204313
    Thanks Chris,
    I have spoken with ECA and they confirm that a very limited number of machines are still a couple of months away. These will be the Dual Boiler PID Lever Vibe pump version. Other models may follow later on and I guess that most configurations will be available via special order.
    We are now accepting advance orders.
  1. Replies: 5
    Last Post: 28th June 2011, 05:40 PM
  2. HX v Dual boiler
    By matt_clem in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 1st June 2010, 09:25 PM
  3. HX vs dual boiler
    By melmac in forum Brewing Equipment - Pointy End ($1500-$3000)
    Last Post: 24th July 2007, 11:11 PM
