Results 1 to 3 of 3
Thread: External Pump & motor needed
    Jul 2008
    41
    I just bought a single group Gaggia Visacrem GX machine and found out it has no pump or motor :(.
    They are about $500 new (more than I payed for the machine).
    does anyone know where i can purchase a second hand one?
    Thanks.
    Cam
    Jul 2008
    Port Fairy
    2,993
    Re: External Pump & motor needed
    Hi Cam,
    to get the price down a little get in touch with Roehlen Industries in Moordialloc (Melbourne), they are the Procon importer and have reco pumps and can fit it to a new motor for you price should be more like $300 ish for both. Tell them you are looking for an espresso machine and the pressure range you are looking for as the relief valve springs vary.
    ie if you are drawing from mains with a pressure reducing valve (350kpa) you need the pump to add about 600 kpa or if you are drawing from a tank the pump needs to add all the pressure (950kpa)
    The other choice is try second hand catering equipment places you might get lucky.
    Jul 2008
    41
    Thanks, I will try them.
    I had a look online at the different pumps they sell.
    They have different flow rates.
    Does anyone know what flow rate the pump should be?
    Cam
  1. External pump and motor
    By Big_John in forum Brewing Equipment - Midrange ($500-$1500)
    Last Post: 12th August 2009, 08:15 PM
  2. External pump
    By freney in forum Brewing Equipment - Extreme Machines ($3000+)
    Last Post: 25th March 2009, 03:15 PM
