Results 1 to 4 of 4
Thread: Syphon Timing, Dosing and Grinding
    Jul 2008
    Port Fairy
    2,993
    Well I am in a quandary at a Syphon demo at St Ali yesterday run by Toshi and he was dosing really differently to me and to most others here from the recent posts on Syphon brewing.
    Brief run down was coarse Plunger, 24g using 150-160ml of water in a TCA2 Hario and a 45 second brew time. Stirring method discussed elsewhere. Also using a really light roast at only a couple of days old. From the talk he was giving he was aiming to get 1 cup of coffee (130ml) and the extra water being absorbed by the bean mass.
    Up to now I have been running 7-8g/120ml of fine plunger and have settled on about a 60 second steep time.
    The high dose and the coarse grind makes the draw down time really quick which is a benefit if you are trying to manage bean contact time.
    I have tried some shorter brew times around the 40 second mark using my normal dose and grind but found it weak. So up he dose shorten the time and coarsen the grind or leave it how I have it now is the question?
    Call this a straw poll of the 3 major factors apart from stirring techniques How long, How much and How coarse?
    Apr 2007
    1,687
    Re: Syphon Timing, Dosing and Grinding
    Quote Originally Posted by 585F5B545C564353545D3A0 link=1237260092/0#0 date=1237260092
    Call this a straw poll of the 3 major factors apart from stirring techniques How long, How much and How coarse? *
    Depends on the bean and roast profile I reckon. hehe
    Jul 2008
    Port Fairy
    2,993
    Noooo another variable ;) Sticking with 8g on the Esmeralda BTW couldnt bring myself to use so much to get so little ::)
    Senior Member redzone121's Avatar
    Oct 2007
    New Zealand
    1,162
    Nice one Yeeza, trust you to throw more headache in to the mix. We missed you on Sunday 8-)
    Yes BF came home with many tweaks to be tested too, ah such is life, its not easy being a Snob, didnt you read the fine print when signing up?
    I was surprised by grind size :-/
    CB
  1. Crack Timing measurements
    By GrahamK in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 30th August 2010, 12:42 PM
  2. Dosing, Grinding and Extraction Lenght; variables inter-linked
    By oneday in forum General Coffee Related...
    Last Post: 8th December 2009, 10:30 AM
  3. [m]: SB EMO6910 - When do you start timing the shot?
    By Dimal in forum General Coffee Related...
    Last Post: 29th August 2008, 10:37 PM
  4. Timing you shots - When do you start timing?
    By javabeen in forum General Coffee Related...
    Last Post: 11th March 2007, 09:39 PM
  5. Timing of shot pours
    By Bullitt in forum Brewing Equipment (non-machine specific)
    Last Post: 29th May 2006, 08:31 AM
