Results 1 to 7 of 7
Thread: Grinds in my coffee - Stove Top
    Sep 2010
    Sydney, Australia, Australia
    218
    Hi guys,
    I'm not sure if it's me doing something wrong or if this is normal but am I suppose to get leftover grinds in the cup brewed from Stove Top?
    I have a stove top similar to a Baletti.
    P.S. note this only become an issue when I am on holidays as I'm on makeshift system (Grindripper with Stove Top) so I'm quite inexperienced.
    Dec 2011
    PRL
    2,574
    You might be grinding a little too fine. Need to be a bit coarser than for an espresso machine. Can't say I've ever experienced grinds in the cup (but maybe I haven't been super observant).
    Sep 2010
    218
    I have a lot.. it's like a soupy coffee soup.
    Would you have a picture of how course I'm suppose to have the grinds?
    The holes on my stove top are also quite big so I don't actually understand how the grinds DON'T pass through.. stove top plate attached..
    Dec 2011
    PRL
    2,574
    I don't have any photos of my own, but if you google "Making Espresso in a Moka Pot" you'll find a non-commercial site that has one photo of the grinds that looks about right (I might go a touch coarser than the photo).. Or just google "grinding for moka pot" and click 'images'....you'll find some relevant photos.
    Not a Shoe Jimmytheboot's Avatar
    Jan 2009
    246
    Its better to be too coarse then too fine, so start very coarse and go fine as you dare, too fine and it will be burnt/bitter tasting even with milk and sugar
    Aug 2004
    2,312
    The grind for a stove top espresso is quite a bit more coarse than that used for electric / pump driven espresso machines. It is close enough to a filter grind.
    I would be looking at your technique. Make sure you fill the filter funnel completely and DO NOT tamp in the same sense as people do with modern electric type machines. Its ok to settle it gently by tapping it (the funnel) on a breadboard or similar, the grinds will settle down and leave space for you to refill the funnel until it is full again. The funnel must be full when you assemble the two halves of the pot.
    Done properly, it would be unusual to have grinds coming through the machine.
    Hope that helps.
    Sep 2010
    218
    Thanks guys - so looking at the photos on Google, I'd say the grind particles should be bigger than the holes?
    Is this correct?
    Just need some sort of gage to know where to start on the Grindripper before I kill my arm..
  1. should coffee grinds sink or float??
    By lachier in forum Home Roasting - Tips, Tricks, Ideas
    Last Post: 31st May 2013, 02:06 PM
  2. Belman Stove Top Coffee Maker
    By Bullitt in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 18th April 2012, 02:07 PM
  3. Bitter coffee in stove top brikka
    By potroasted in forum Brewing Equipment - Manual Coffee Brewing Processes
    Last Post: 10th April 2009, 11:18 AM
  4. What do you do with your coffee grinds?
    By Javaphile in forum General Coffee Related...
    Last Post: 15th March 2007, 01:19 PM
