Page 11 of 11 FirstFirst ... 91011
Results 501 to 519 of 519
Like Tree195Likes
Thread: THE ULTIMATE cold brew / cold drip thread
  1. #501
    Jul 2007
    7
    My immersion Brew method involves a 5lt food grade container (Bunnings) 500g Ethiopian natural single origin. 2+lt of water to make 2lt of concentrate which I then dilute with 2lt if water in my keg.
    I strain this using a strainer plus mesh (I am looking at picking up the bag from this https://ikegger.com/collections/sale...w-coffee-maker to make the process easier)
    I normally squeeze out extra fluid from the, however today I let it sit and slowly drip out over 3 + hours (agitating every so often to increase drip/flow rate. I wonder if this is going to produce some cold Brew, cold drip hybrid ��
  2. #502
    Nov 2013
    1,047
    Just saw this on Brooklyn Nine Nine and it reminded me of when I made my first batch of cold brew (except the room temperature thing!)
    https://youtu.be/TAa-7_tj5W8
  3. #503
    Oct 2009
    Geelong
    982
    Just saw this on Brooklyn Nine Nine and it reminded me of when I made my first batch of cold brew (expect the room temperature thing!)
    Hahahaha, am not a big cold brew/drip fan, but just recently started watching Brooklyn 99, absolutely love it XD
  4. #504
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,085
    giggled like a schoolgirl! That’s classic. My boss at the cafe could relate as he had a couple of moments when we were developing our cold brew last year where he thought to himself- “s@#t I’ve just drunk a lot of coffee!”
  5. #505
    Dec 2004
    Earth!
    15,182
    HAHAHAHA...Ask Andy about his first experience with cold brew/press. I'd brought some with me not only for the journey but for him to taste as well. I pulled out the container of it and handed it to him and turned back to get more makings for it and by the time I turned around he'd already poured a hefty cup of it, sipped for a taste, liked it, and polished off the rest of the cup, finishing the 150ml or so of it as I turned back to him. As he started commenting on the nice acidity level and flavors etc I just stood there with a dumbfounded look on my face and as he noticed I started laughing. "Dude! Do you realize how much coffee you just drank!?!" "What do you mean?" "That was my concentrate!!! You just swigged down the equivalent of somewhere around 10 shots of espresso!!!" Great hilarity ensued! HAHAHAHAHA
    Java "Jazzed up Andy anyone?" phile
    Dimal, simonsk8r, LeroyC and 3 others like this.
    Toys! I must have new toys!!!
  6. #506
    Zee
    Zee is offline
    Member Zee's Avatar
    Aug 2018
    74
    BWAHAHAHAH! I would have loved to have seen that!
    Z...
  7. #507
    Zee
    Zee is offline
    Member Zee's Avatar
    Aug 2018
    74
    So, anyone used a Mazzer Mini to grind for cold brew? I know it's an espresso grinder, but figure if set coarse enough, should do a reasonable job for large volumes. Our poor little Baratza Encore can only last so long grinding 2kg of beans at a time..
    Z...
  8. #508
    16,358
    Grinders like the Mazzer you refer to above can grind to what ever size you want. It is at the espresso end of the scale that tests the mettle of what a grinder is capable of, not the coarser end of the scale...
    Few grinders will be capable of grinding 2Kg of beans in a single session though. The "Duty Cycle" on the nameplate will tell you what is possible otherwise you will risk overheating and burning out the motor.
    Zee
    Zee is offline
    Member Zee's Avatar
    Aug 2018
    74
    Good point, probably smarter to grind in multiple smaller batches, but will look i ti that. Though I suspect the Mazzer Mini is far more capable of larger batches than a Baratza Encore. Thanks for the tip, though, eill help with keeping the grinder in good shape, and certainly whilst I did consider the afffect of it overheating on the beans, I did not think of the motor.
    Z...
  10. #510
    16,358
    Ah, no...
    No typical commercial or prosumer grinder can be used in the way you are describing.
    If you think you're going to be grinding these sorts of quantities, then you need to look at industrial rated grinders such as a Mahlkonig or Ditting grinder. These will do what you want very comfortably...
    Caffeinator and Zee like this.
  11. #511
    Zee
    Zee is offline
    Member Zee's Avatar
    Aug 2018
    74
    Ditting and Mahlkonig are well and truly out of our budget right now, sadly. I do agree with your point, though.
    Z...
  12. #512
    Sep 2013
    2,085
    Get a Bunn or Mahlkönig shop grinder. They start at around $1000 which is money well spent to be able to do what you want to do. Nothing else is really worth considering, including the Mazzer Mini.
    Dimal and Zee like this.
  13. #513
    Zee
    Zee is offline
    Member Zee's Avatar
    Aug 2018
    74
    Been searching for Bunns forever, they simply seem impossible to find with 220v/60Hz. Malkönig shop grinder is one I've not even heard of. Google time...
    Z...
  14. #514
    Dec 2004
    Earth!
    15,182
    Grindmaster is another good brand for a shop/bulk grinder. A bit over 13 years ago I managed to score a very lightly used Grindmaster 875 demo unit which has been in regular use ever since grinding 2.5kg Cold Press batches as well as all my non-espresso (Siphon, Aeropress, Pourover, Filter, French Press, etc.) grinding needs. Its' burrs are guarranteed for over 13,600kg so it's unlikely I'll ever need to replace them.
    Java "Grind it up!" phile
  15. #515
    Zee
    Zee is offline
    Member Zee's Avatar
    Aug 2018
    74
    Thanks for that one - will expand my search!!!
    Z...
  16. #516
    Zee
    Zee is offline
    Member Zee's Avatar
    Aug 2018
    74
    Been doing a bit of searching, but not sure I know which model you are referring to re the Mahlkonig -do you mean like a Guatemala, or Kenya
    Z...
  17. #517
    Dec 2004
    Earth!
    15,182
    Quote Originally Posted by Zee View Post
    Z...
    Mahlkönig is a brand of grinder, not coffee beans.
    Java "Grinding away" phile
    Barry O'Speedwagon likes this.
  18. #518
    Nov 2013
    1,047
    Guatemala and Kenia are current Mahlkoenig models...
    Javaphile likes this.
  19. #519
    Dec 2004
    Earth!
    15,182
    Aaahhhh...I stand corrected.
    Java "The 'Kenya' threw me" phile
    level3ninja likes this.
