Results 1 to 8 of 8
Thread: Unkown machine - help need
    Apr 2015
    3
    My brother got it for a $1 in an op shop. Absolutely no info on the machine.
    Any ideas.
    https://www.facebook.com/photo.php?f...9984545&type=1
    Jun 2014
    31
    It looks like a stovetop steamer - not a bad price assuming it works
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,358
    Yeah most probably a milk steamer. The ones that do both coffee and steam have 2 outlets of some sort, although there was one Italian one that did both coffee and steam through a single pipe like this. If it's able to do coffee it will have a basket inside it as per a Bialetti.
    Jan 2014
    Sweden/Germany
    141
    Apr 2015
    3
    It has a basket inside.
    I have not been able to get my hands on it for a full inspection.
    When I do I can photograph and describe it workings.
    Apr 2015
    3
    https://scontent-lax.xx.fbcdn.net/hp...d5&oe=559B58AB
    It has Made in Italy inox 1810 and DD graphic on the base
    Sep 2013
    2,358
    Quote Originally Posted by cutandweld View Post
    So it's 18/10 stainless steel from Inox in Italy. That's good, if you're gonna have a stainless stovetop it might as well be a good one. It's still a little hard to tell from the photos, but I have a feeling it just makes coffee. As I said above I have seen one in the past that has a single outlet for both coffee and steam, but I'm not sure this is one. If it's able to do both then the valve on the outlet will have two distinct positions and probably some markings to tell you which is which. Even if it is only capable of doing one thing at a time you can still use it for either. So for example if you were to brew an espresso with a Presso you could then steam some milk with this separately. Whatever it does, it looks like a steal for $1.
    Mar 2015
    Reno, NV USA
    17
    Not from INOX. INOX means non rusting or stainless steel in several European languages. I have seen it used on German, Swiss and Italian items including some Swiss army knives.
