Results 1 to 6 of 6
Like Tree3Likes
  • 1 Post By pyrmontboy200
  • 1 Post By Steve82
Thread: Manual drip brewing - how do you go about it ?
    Apr 2009
    Republic of China
    162
    Most drip devotees are probably aware of the two main categories of brewing in this category seen around the net, those being infusion and permeative. I made some videos of myself preparing both styles linked below. You could find much better pours elsewhere on the net quite easily, in fact I had some distractions in the background when filming. But they do demonstrate the different styles quite well.
    Permeative drip brewing is about keeping the brew water level in your dripper to around the level established from the initial bloom. You pour in concentric circles in the centre, distributing turbulence as evenly as possible in a relatively small diameter, while maintaining a decent sized bank or moat of coffee around the outside. In the Kalita 101 I'm using in the attached video, you can get away with keeping your pour to around the diameter of a 50c piece. With the V60 probably more like a 20 cent piece. This style of brewing calls for super high ratios of up to 1:10, 1g of coffee to 10ml of water, and quite coarse grinds. It tends to highlight the acidity present in a bean. It can be good for darker roasts which may taste too flat using the infusion method.
    https://www.dropbox.com/s/50ui1k8qya...ative.MOV?dl=0
    Infusion drip is a simpler method, pour out your water onto the grounds at your chosen speed, and wait for the draw down. Stagger your pour if you want, e.g Barismo method. Here the coffee is getting saturated with water and you really are aiming to cover the bed of grounds with water after the bloom. The key here is that you are not too fussed about creating agitation, while in permeative brewing you are trying as hard as possible to avoid it. After that final pour, the grind size of the coffee will control the rate of draw down. So depending on how fast you want to pour out in the first place, you will need to adjust the fineness so you get your preferred brew time, which for me is around 2-2:30, including a 30 second bloom. Typically infusion type brewing calls for a finer grind than permeative, and a shorter brewing time. I typically grind significantly finer than presented in this video.
    https://www.dropbox.com/s/u2jq5w5rjy...rsion.MOV?dl=0
    A lot of the instructional stuff you see on the net is a hybrid of both methods. I find generally that infusion gives a darker, richer more satisfying cup. Think about a long black from your espresso machine, but with more dimension. Permeative brewing gives a cleaner cup but can be too acidic if not brewed long enough, or if brewing a particularly light roast. Because caffeine is easily dissolved into the water the high ratios when using permeative mean quite a strong cup caffeine wise, even though the brew tastes quite mild.
    With the finer grind, infusion can be quite temperature sensitive. I use ~92 deg C as my baseline, and go up or down from there. Just like an espresso machine, every new bean requires dialling in. One way to trouble shoot your grind is to continue adding water and brewing after you've removed the dripper from your server. If these dregs taste bitter then it is likely that you've extracted all the goodness already from the bean earlier on, and may need to coarsen your grind up. If on the other hand you are still getting sweetness and good colour in the brew water than you may want to fine up your grind. This is assuming you are holding brew time and temperature fixed.
    So drip brewers of CS, what is your chosen approach to brewing? What beans are you drinking through your dripper at the moment ?
    sprezzatura likes this.
    Feb 2012
    Central Coast NSW
    684
    Mainly 1 Cup V60, also have 2 cup, I guess you would call it the infusion method.
    Quite a fine grind 12g / 200 - 210g water, 30g bloom wetting all the grounds making sure none stick to the sides wait 30 sec.
    Pour the rest of the water slowly / evenly in small circles finishing up around 1:20, jiggle and 1 tap for even coffee bed.
    Drawdown finishes 2 - 2:20.
    TDS 1.35 - 1.42 / 20.5 - 21.5% extraction yield. This is with Vario + flat steel brew burrs.
    Lido 3 - small conical, TDS 1.28 - 1.35 / 18.5 - 19.5% extraction yield.
    Med - light roast just finishing or finished first crack + 30sec, well developed, sweet, full ripe fruits, balanced acidity, 3 dimensional in its structure. Fresh crop Colombia, Rwanda, Kenya = delicious.
    Senior Member sprezzatura's Avatar
    Dec 2013
    Hervey Bay, QLD
    930
    Quote Originally Posted by pyrmontboy200 View Post
    I'm using an infusion method with a Hario 380ml sock; the grams in vary on the bean/roast but I did 40g of Ethiopian Sidamo Ardi @CS8+ and enjoyed a rich, spicy, blueberry brew. My next toy is a Brazen and I'm looking forward to some water temperature and drop rate control.
    Apr 2009
    Republic of China
    162
    Thanks for the replies. Steve82 what setting on the Lido 3 do you use? On the Lido 1 for v60 infusion I use 1.5 revolutions coarser from zero. Zero I regard as .25 turn from burr lock. I'm aware they are different burr sets. From the drawdown time sounds like a pretty similar grind size to mine.
    Sprezzatura, the sock is such a great minimalist piece of kit. I use a cloth coffee filter in my v60, I like that it lets just slightly more oil through than the paper. When you switch to cloth you notice the difference immediately. Look forward to hearing about the Brazen experience.
    Dec 2013
    Hervey Bay, QLD
    930
    I concur: better flavour and depth out of cloth. It allows full appreciation of that precious Ethiopian coffee.
    Feb 2012
    Central Coast NSW
    684
    I have zero line set where the burrs lock, grind setting usually somewhere around line 7.5 to 9 depending on 1 cup / 2 cup , origin / roast.
    From memory I think 16 lines make up a full turn. When I first got it and tried out espresso, the range for choker / gusher was between 2.5 and 3...
