Results 1 to 9 of 9
Like Tree6Likes
  • 3 Post By Otago
  • 1 Post By Otago
  • 1 Post By Otago
  • 1 Post By LeroyC
Thread: Aeropress filter comparison
    Sep 2012
    Hobart TAS
    235
    With a kilo of supermarket beans gifted after a fund raiser I thought I should try to put them to good use before throwing them out.
    So I ran a brew through each of the Aeropress filters I have acquired over the years, and placed an Aeropress filter behind each to gauge what by-passed each filter. (including the Aeropress filter ie 2 Aeropress filters)
    I think the results are fairly predictable and it is clear that if you want the cleanest brew the Aeropress filter is the best option. The IMS 35 micron is close but you will be needing to give it a Caffeto bath frequently, because it quickly clogs up. The Aeropress is more convenient and you can buy a lot of 350 filter packs for the price of an IMS filter!
    It was not practical to place an Aeropress filter behind the Prismo metal filter, so I had to take a brew and run it through the Aeropress. I don't think all of the fines were filtered the second time, so this probably appears clearer than it really is.
    Dimal, simonsk8r and level3ninja like this.
    Senior Member LeroyC's Avatar
    Sep 2013
    Woodend, New Zealand
    2,118
    Cool experiment to run. Interesting to see the results, even if thereís no surprises. I pretty much always default to either 1 or 2 paper filters as I think that creates the sort of brew that I like to make with the Aeropress. Iíve also got an RGB and a Kaffeologie S Filter. The RGB is pretty much a spare that I donít rate. The S Filter does a great job if you want something with a bit more body. Iíve got an Ameuus on the way via Kickstarter. Thatíll be interesting to try.
    Oct 2009
    Geelong
    1,010
    Awesome, thanks for sharing that Otago, cool experiment
    Sep 2012
    Hobart TAS
    235
    Thanks LeroyC and simonsk8r.
    It's kind of a relief LeroyC to know there is another out there with gadgetitis as far as Aeropress accessories are concerned.
    I'm also waiting on the Ameuus set which look interesting. They look as though they will be easier to clean than the IMS filter, while still getting a result close to the paper filters.
    simonsk8r likes this.
    Sep 2013
    2,118
    Yeah Iím looking forward to it too. Iím not really interested in a metal filter that replicates the paper filters as Iím quite happy using 1 or 2 paper filters for a clean brew. However a metal filter that goes close could be awesome as it will hopefully produce a cup with a bit more body, but still plenty of sweetness and brightness. This is where Iím hoping the O2 will sit.
    The only other filters Iíve tried are another RGB model and a fairly generic one (the first Able maybe?), both of which are gone now as they were unimpressive. I actually use my Oomph more than my AP these days as I love the brew it makes.
    I didnít bother with the Prismo as I just donít see the point really. The Aeropress does what it does really well, I donít get why people want to eke pretend Ďespressoí out of it. The Puck Puck on the other hand looks very interesting and I might have to grab one at some stage.
    May 2006
    81
    Hey Otago, do you mind commenting on the grind you used?
    Was is determined by one particular filter or what you used for the AP in general?
    Also did you change the grind and see any differences (in terms of taste with each filter or residues in second filter paper)?
    Sep 2012
    Hobart TAS
    235
    Hi dischucker
    The grind was 8 marks from zero on the Lido 3, which is mid drip range and the dose was the same for all filters.
    The exercise was merely to give a visual indication of the amount of sediment bypassing each filter for that dose.
    Trying to determine the best taste outcome across that number of filters is beyond my capacities. Sorry, but I'm not Socratic Coffee.
    dischucker likes this.
    Sep 2013
    2,118
    My Ameuus o2 filters arrived during the week. I havenít had a chance to try them yet, but will get to do so today. Iím looking forward to it and will report back. Itís a very nice looking little kit, although having metal filters that are almost as soft as paper is slightly unnerving.
    Sep 2012
    Hobart TAS
    235
    Looking forward to your thoughts. Mine mustn't be far away. Although you say it's a nice looking kit, a recent posting by Alcheng88 on Instagram had a bamboo stirrer covering the tail on the orange logo, which left one wondering why he thought a nicely packaged orange condom should be featured amongst his coffee gear.
