Results 1 to 12 of 12
Like Tree9Likes
  • 1 Post By Dimal
  • 1 Post By roosterben
  • 2 Post By level3ninja
  • 2 Post By Dimal
  • 1 Post By Dimal
  • 2 Post By Yelta
Thread: Aeropress add-on...
    17,415
    Aeropress add-on...
    Something that may be of interest to Aeropress owners...
    https://dailycoffeenews.com/2019/09/...ver-the-world/
    roosterben likes this.
    Oct 2015
    230
    Highly recommend, I have one I picked up from Alterative Brewing and they work a treat.
    Will be back to making cold brews for my avo coffees at work.
    A bit fiddly to set drip rate initially but once you get used to it makes good cold brew.
    Dimal likes this.
    Dec 2019
    5
    Hey, would you recommend the puckpuck over a stand alone cold drip like the Bruer?
    Sep 2012
    Hobart TAS
    321
    Aeropress add-on...
    How much do you need to brew? They're pretty much on par 450ml for the Puck Puck vs up to 600 ml for the Bruer.
    If you accept that they both do an affective cold brew then the price differential becomes a major factor.
    Do you have an Aeropress already? If so, only the Puck Puck adaptor is needed. Approx $40 vs well over $100 for the Bruer. You also have the multi-use offered by the Puck Puck vs the single use nature of the Bruer.
    I found the Puck Puck simple to use once you get past the initial lack of familiarity.
    Nov 2013
    1,832
    I would recommend the Hario Mizudashi cold brew jug. It's $30-40, stand alone jug. One batch makes approx. 1L. I put 80g of coffee to approx 1100ml water and leave it in the fridge for 20hrs. I used to do it on my Breville BCG820 at factory inner burr setting and main setting of 50. I now do it on my Niche Zero at 40-50 depending on the coffee.
    Dimal and Yelta like this.
    Oct 2015
    230
    Another which may be the same jug as Hario one above is is T2 jug-a-lot small. They are easy to find second hand as heaps of tea buy for iced tea and never use.
    Nov 2013
    1,832
    The only real difference between the T2 jug and the Hario is that the Hario is easier to clean because the bottom of the coffee holder part is removable, giving you a straight through path to rinse the grounds out. I've never used our T2 jug for coffee but it can be quite painful getting the last of the tea leaves out.
    17,415
    I would recommend the Hario Mizudashi cold brew jug. It's $30-40, stands song jug. One batch makes approx. 1L. I put 80g of coffee to approx 1100ml water and leave it in the fridge for 20hrs. I used to do it on my Breville BCG820 at factory inner burr setting and main setting of 50. I now do it on my Niche Zero at 40-50 depending on the coffee.
    We have one of these too...
    So easy to use, clean and re-use again and again.
    Makes a great cold brew into the bargain as well...
    Yelta and level3ninja like this.
    Senior Member Yelta's Avatar
    Jun 2009
    Moonta SA.
    7,247
    Morning Mal, you guys have piqued my interest, thinking of buying a Hario Cold Brew Pot, do you reckon the Mazzer Mini will grind coarse enough for this method of extraction?
    May 2008
    4,196
    Easily. .
    17,415
    Quote Originally Posted by flynnaus View Post
    Easily. .
    Agree with Steve, no problem at all...
    You don't actually need to grind all that coarse to be honest.
    Have found that a grind slightly finer than that used for Drip Coffee works best for us.
    Makes for a lovely rich brew with loads of flavour, sweetness with no bitterness at all...
    Yelta likes this.
    Jun 2009
    Moonta SA.
    7,247
    Order placed with my favorite supplier $30 delivered to my door, looking forward to giving it a test run.
    Dimal and level3ninja like this.
